Question: can the projector headlights take d2r/d2s bulbs?
Old Oct 28, 2006 | 11:27 PM
TopSpeedNY's Avatar
I have a question can the halo projector headlights for 00-03 take d2r/d2s bulbs if so how and i would need instructions how/to for the headlights as well installing them if possibale thank you very much,
Mike
Old Oct 29, 2006 | 07:59 AM
MIXXMAX's Avatar
D2R's are made for reflector-type housings, and D2S' are made for projector-type housings. To answer your question, whichever method you use, you must modify the base of the bulb for the oppsosite housing it was intended for. For example, a D2R bulb's base and black lining on bulb must be altered in order to make it work on a projector. Same with D2S...the base must be altered to make it work in a reflector housing. Your best route is to use the bulb what is was intended for.
Old Oct 29, 2006 | 08:00 AM
steven88's Avatar
Need A Light?
D2R will not work for projectors....only D2S will
You can also use D2C which is a new type of bulb....they fit both R and S
Old Oct 29, 2006 | 08:14 AM
TopSpeedNY's Avatar
how is this possible steven88 and how can i get instruction on doing this thanks big bro,
Mike
Old Oct 29, 2006 | 08:32 AM
MaximaPolak's Avatar
If you have the Ebay projector headlights, you should use H3 bulbs. If you retrofit a projector that accepts D2S bulbs, then you should use D2S.
Old Oct 29, 2006 | 02:56 PM
808MAX-SPEC's Avatar
If you can change out your H4 bulbs, then all you have to do is remove your OEM headlights. It does require a manuvering the headlight remove and install but it shouldn't take more than an hour to do.
Check out page 3 on my cardomain site.
doctorpullit
Mar 29, 2016 11:08 AM
mpbclutch33
Dec 26, 2015 11:11 AM
knight_yyz
Nov 1, 2015 01:34 PM
Noela
Sep 26, 2015 08:22 AM
