Question: can the projector headlights take d2r/d2s bulbs?
I have a question can the halo projector headlights for 00-03 take d2r/d2s bulbs if so how and i would need instructions how/to for the headlights as well installing them if possibale thank you very much,
Mike
Mike
D2R's are made for reflector-type housings, and D2S' are made for projector-type housings. To answer your question, whichever method you use, you must modify the base of the bulb for the oppsosite housing it was intended for. For example, a D2R bulb's base and black lining on bulb must be altered in order to make it work on a projector. Same with D2S...the base must be altered to make it work in a reflector housing. Your best route is to use the bulb what is was intended for.
If you can change out your H4 bulbs, then all you have to do is remove your OEM headlights. It does require a manuvering the headlight remove and install but it shouldn't take more than an hour to do.
Check out page 3 on my cardomain site.
knight_yyz
11-01-2015 01:34 PM
