Problems with New Tranny
Old Nov 1, 2006 | 09:13 PM
Reket's Avatar
Well I just installed a rebuilt transmission and put in a spec stage 2 clutch along with a fidanza lightened flywheel. Now whenever i start going in first gear, the car shakes and rumbles quite a bit. Anyone know why thats going on? Thanx in advance!
Old Nov 1, 2006 | 09:20 PM
WielkiWaac's Avatar
MaximaDriver
how about other gears??
Old Nov 1, 2006 | 09:54 PM
Reket's Avatar
only when i start driving from 1st and a lil in 2nd.
Old Nov 1, 2006 | 10:11 PM
matty's Avatar
Clutch Chatter ??
-matt
Old Nov 2, 2006 | 04:08 AM
dgeesaman's Avatar
Maintenance Monster
You're not being specific enough.
Is it rumbling while you engage the clutch? Or is it rumbling while you are accelerating in 1st gear?
Dave
Old Nov 2, 2006 | 10:33 AM
Reket's Avatar
It rumbles as I engage the clutch. Once i release it it shakes until i get to like 1500prm and then it becomes smooth again.
Old Nov 2, 2006 | 02:00 PM
Reket's Avatar
Bump This Thread
Old Nov 2, 2006 | 02:27 PM
matty's Avatar
Thats the clutch chattering. It should go away with time.
-matt
Old Nov 2, 2006 | 03:52 PM
dgeesaman's Avatar
Maintenance Monster
Or it may not.
Was this a new clutch disc, pressure plate and was the flywheel also resurfaced? Because that's what needs to be done in order to reasonably prevent clutch chatter. Note that some lightened flywheels can't be resurfaced, in which case you need to buy new inserts.
Dave
Old Nov 2, 2006 | 09:06 PM
Reket's Avatar
Originally Posted by dgeesaman
Or it may not.
Dave
I bought a brand new clutch with a pressure plate and a brand new lightened flywheel. You think it will go away over time? Or will it go away after my clutch is burned?
Old Nov 2, 2006 | 09:09 PM
matty's Avatar
Do a proper break in and youll be fine. I jsut installed a brand new clutch, flywheel and PP and I have chatter. You need to wait at least 1000 miles before it starts getting better. Keep the revs low, under 3000, and no clutch dumps during break in>>>1000 miles
Old Nov 3, 2006 | 03:20 AM
dgeesaman's Avatar
Maintenance Monster
Well no mistakes there. The only other issue is to make sure the flywheel and pressure plate are cleaned thoroughly with solvent before assembling it.
Perhaps the chatter will go away - for me it did once, but another time not at all. Unfortunately, if it doesn't go away you'll have to change the clutch disc, pressure plate, and flywheel surfaces again.
Drive it easy, don't slip it more than you have to, and avoid chattering it.
Dave
Old Nov 3, 2006 | 09:15 AM
Reket's Avatar
thanx a lot guys for all the feedback. I was thinkin of goin back to the shop and goin off on them cuz they ****ed up. But I guess I'll just wait it out. I current drove like 480 miles on my new clutch and flywheel.
pktaske
May 6, 2016 07:49 AM
Socalstillen
Sep 20, 2015 11:46 PM
iamute
Sep 20, 2015 05:22 PM
pktaske
Sep 4, 2015 08:40 AM
Lowered_a33
Sep 1, 2015 07:49 PM
