alarm keeps going off
Old Nov 2, 2006 | 10:54 AM
maximaintheface's Avatar
my alarm goes off for no reason. also it somtimes goes off when certain cars use they keyless remote. why would this be? there was another non factory alarm but i took it out. i took out all the wire and sensors that i know of.
Old Nov 2, 2006 | 12:35 PM
miatarick's Avatar
I can't believe that you are having the same problem as me. It started yesterday after having the Max detailed. Goes off for no resason.
Any answers out there? Can't pull the anti-theft as it is also the start circuit.
Old Nov 2, 2006 | 01:52 PM
Maxgig's Avatar
look in the posts from yesterday, I just read where other guys were having the same problem. It turns out that it was because water somehow got on the locking mechanism and corroded it. They said there was a fix in the stickies but in the meantime they both just sprayed some WD-40 in the lock and turned their key with pliers to help lubricate it or simply unplugged the sensor.
Old Nov 2, 2006 | 02:28 PM
o ok. ill look for the post.
Old Nov 2, 2006 | 08:11 PM
my lock on my driver side wasnt locking all the way,. i think i got it now.
Old Nov 3, 2006 | 11:03 AM
ok its still going off. is there anything else besides the hood pin and the doors not locking all the way that would do this?
Old Nov 3, 2006 | 01:51 PM
miatarick's Avatar
Yes. Slow down a little.
Mine was being caused by water getting into the connector under the spoiler in the upper trunk lid. Removed the inner carpet, Found the connectors. Opened them up. Dried them out with electonics cleaner.
No more problem.
I did pull the 7.5 ohm fuse from the driver side engine compartment fuse box (marked anti-theft) until it was done
Old Nov 3, 2006 | 04:25 PM
i donbt have a spoiler does that matter?
Old Nov 3, 2006 | 05:58 PM
miatarick's Avatar
That is how the water got to me. And since you live in a fairly dry clime I doubt the problem for you unless you use a high pressure sprayer. Might still be worth a look.
Old Nov 3, 2006 | 10:44 PM
ya i think i got it. i hope so i just sold the car lol
kmitchel
Oct 28, 2015 09:46 AM
zzznightmarezz
Sep 21, 2015 06:32 PM
Shock_and_Awe
Aug 23, 2015 01:02 PM
RussMaxManiac
Jan 3, 2001 06:41 AM
RussMaxManiac
Jan 3, 2001 05:40 AM
