I cant figure out this belt problem
So I changed my alternator and bought a new belt. I started squeaking when the car was cold on start up and it would go away. Then i tightened down my idler pulley and it didnt do it for about a week. Now all the sudden it squeaks for a bout 5 minutes after start up. If a belt is too loose i know itll squeak, but what about if its to tight? or is it another part like a bearing.
thanks
thanks
Originally Posted by NYC32798
Did you loosen the idler pulley bolt on the pulley itself before you tightened the adjusting nut?
I guess I have to loosen the adjusting nut then loosen the bolt on the pulley (the one that the pulley spinning on?).
Do I have to move the pulley up or down to adjust the tension ?
Can any one make a write up with instructions ?
Originally Posted by matrix11229
How do you adjust the belt tension ?
Originally Posted by konak85
you must first loosen the nut in the center of the pulley itself(you will see it when you get underneath), then tighten the nut on top then tighten back the first nut in place, not too tight though. thats pretty much it.
How tight do I have to tighten the adjusting nut on the top ? I wanna loosen the belt tension because of the vibrations.
Originally Posted by mastercater7
so if its too tight could that be why its squeaking? i found today its only after starting if the defrost is on
Try to tighten the belt tension a bit and see if it's squeaking.
I need to loosen the belt tension.
Which one of the two nuts you mentioned actually moves the pulley up and down ? I see a label on the top nut - "Tighten after adjustment".
Top nut moves belt up or down -- effectively tightening or loosening the belt. The smaller nut in the center of the pulley helps keep the pulley in position. Loosen that nut so the pulley can move (but don't loosen all the way or it will not hold the pulley's position) then go back to the top nut and loosen/tighten. Once the belt is in the desired location, tighten the center pulley nut to spec.
trungg86
Sep 4, 2015 04:58 AM
