mirror garage door opener
I need to set up my new remote with my mirror and i forgot how to do it. im not too lazy to look in the book, my book got robbed when my car got broken into two years ago. some help would be much appreciated. thanks
hold the remote a few inches away from the mirror and hold both the button that you want to program it to and the remote for about 20-30 seconds...it will flash slowly and once programmed it flashes rapidly which is when you can let go of both buttons
hope this helps
dan
hope this helps
dan
Haunt, forgive me,
Prjct,
Keep your laughs to yourself, because I already know I deserve them!
I had my mirror replaced by Nissan. The Homelink button was peeling off, paint wise.
The service man said it took him a bit to get the car to me because he was calibrating the compass. Eric watched him....closely.
That was over a week ago. I was getting aggrivated because my mirror would go between 'c' and an actual direction.
Finally last night I went to a huge parking lot and spun my three circles counter clockwise and wait for it to reset.(Rather, I spun my three circles in the car, not just me outside spinning the circles mind you) It did, but I still wasn't convinced that it solved my issue, so I whipped out the manual, read it and realized the service guy may have spun circles, but he didn't select the correct region on the map! I don't live in region 8-Tennessee or GA.
SO I reset it to 9 (SC). I spun my three circles and it tracked right away, and even faster than my last mirror!
Just had to share! Promise I'm not a blonde!
Prjct,
Originally Posted by haunt14
thanks, is there anything special i have to do if the button has been programmed already with a differant remote?
I also don't know why you would have to clear the memory because I would assume that the new remote would jsut over-ride the signal or w/e was there before with the old remote.
I have tried so many times and it just doesn't work. Does it just not work with my garage doors? I have gotten new ones and with my previous cars, they had worked with my previous garage doors.....
Any ideas?
Any ideas?
Any ideas?
Any ideas?
Hope this helps, thats what I did and it worked for me.
I have also heard that if you have a 'rolling code' for your garage, programming can be a bear. On some older models, it isn't possible to program your Homelink.
By 'rolling' I mean that it is digitized to create new codes every so many seconds. The older garage doors allowed you to chose the code by literally entering a code in the receiver as well as the ceiling mounted motor housing!
Originally Posted by Zargon
Maybe. Program the homelink button on your mirror as described above. For my garage doors, I had to do some additional steps. Look on your garage door opener (the actual motor), there is probably a red button. You need to press this button and then press the homelink button in your car (for mine I had 30 seconds to do this).
mine works on normal garage doors(from 20 yr old models to new ones).... but i cant get it to work on my condo (common) garage doors.... the remote for my condo looks like a normal one... but the security folks have to "program" it.
anyone here living in a condo... managed to get theirs to work?
REDinLV
Aug 15, 2024 12:30 AM
magiconthetire
Oct 26, 2015 09:03 PM
