Weird Window Problem
Old Nov 27, 2006 | 03:08 PM
mist max2000's Avatar
ok well I am having problems with the passenger side front and rear window. From the drivers seat controls they work perfecty fine, but from the passenger side controls they go down fine but dont go back up...?.. at first i only noticed the passenger side window and thought it was the button going bad then i realized that the back one does the same thing. is it just a coinsidence? could it be electrical? and any advice on fixing this problem? do you think just putting new buttons will fix it?
Thanks in advance guys
Old Nov 27, 2006 | 04:18 PM
mickrussom's Avatar
I have a window problem as well, and was wondering if you heard it before they stopped.. Did the windows screech like crazy? My drivers dide window is slowing down, I'm worried about it dying as well.
Old Nov 27, 2006 | 05:05 PM
VaporHead
Spray some silicone down in there window rails.
Old Nov 27, 2006 | 07:02 PM
no my motors are fine from the dirvers side they go up and down.. just they go down fine on the passenger side just not up...anyone have this problem?
Old Nov 27, 2006 | 07:22 PM
VaporHead
I've seen more then one switch go out at once. I would just swap them out. If you are handy with a multimeter, you can test for power at the wire leads and ohm out the switch.
Old Nov 27, 2006 | 07:34 PM
okay's Avatar
yea, i have the same problem. the button on the front passenger side window ocassionally doesn't wanna work, but the control on the driver side always works for that window. i'm thinking its a faulty switch, have yet to fix it. lemme if you fix it.
thanks
Old Nov 28, 2006 | 12:13 PM
Czerkas's Avatar
apparently nissan sucks at making power windows.
Old Nov 28, 2006 | 12:44 PM
03MAXTNR's Avatar
has anyone had problems with there rear defrost taking 25 minutes to clear the rear window. ive already had a new window put in. if so what can i do to fix this
Old Nov 28, 2006 | 01:01 PM
nismo_star's Avatar
need a window switch...and thats it.
nissan does not suck at power windows, its just unfortunate events that do occur, I've seen it all...so stop being a lemming.
Old Dec 2, 2006 | 08:17 PM
yukster's Avatar
Ditto on the power windows... my front passenger and rear driver's side switches are bad. Same symptoms. I can control it from the front driver's controls fine, but at the affected door themselves, they either don't go up or down.
Old Dec 2, 2006 | 11:25 PM
hmm must just be the d@mn switches i wonder how much the stealership is gunna try to take advantage of you for these
Old Dec 3, 2006 | 06:12 AM
MaximaGT-R's Avatar
I'm a Happy Man!
shouldn't be to expensive at the slealership.
Old Dec 3, 2006 | 03:07 PM
towinnh12387's Avatar
When i first bought my 00 max the pass front window did that. So me being so smart I took apart the pass switch and thought I fixed it cause the pieces inside were all messed up. So when I plugged it back in it smoked and toasted the main switch and passenger switch. So I had to pay for 2 new switchs. Then recently my Driver auto down would go all crazy and the pass window did the same as it was before. I took it out and pushed the harness in all the way. Now it works perfect all the way around. Just might help ya out!
thenewguyy
Sep 12, 2015 11:12 AM
bennuss
Sep 11, 2015 05:55 AM
markevans999
Sep 10, 2015 04:29 PM
ef9
Sep 5, 2015 11:18 PM
maximusrising
Sep 4, 2015 06:31 PM
