rattling noise
Old Dec 6, 2006 | 07:28 PM
platinum03SE
rattling noise
hey guys i seem to be hearing a small rattle noise only when ide give my motor a quick rev, maybe to only 2500 at the most. i only hear the noise when my RPM's begin to drop. i hear the rattle over by the timing chain area. i dont know what the noise is but any input would be great.
seth
Old Dec 6, 2006 | 08:10 PM
MaximaGT-R's Avatar
I'm a Happy Man!
i bet you if you jack up the car and have someone rev it and you listen closely to the catalytic converter you will find out that the rattle is comming from inside the catalytic converter. some how the mesh grille on the inside of it is lose.
Old Dec 6, 2006 | 09:02 PM
NmexMAX's Avatar
dot dot dot ...
If the cat is dead, that means you'rerunning lean, and damaged it with heat. My cat is fine 4 years and 80k miles later. Something else might be(is) wrong.
Old Dec 6, 2006 | 09:05 PM
platinum03SE
im pretty sure its not the cat, my car only has 44k on it. sounds like a chain or some plastic rattling.
Old Dec 6, 2006 | 09:11 PM
NmexMAX's Avatar
dot dot dot ...
Chain and plastic noises are very different. Is it metal or plastic sounding? Are you familiar with spark knock sounds vs rod knock?
Old Dec 6, 2006 | 09:14 PM
platinum03SE
well ide like eliminate rod knock because its been like this for a little while now and it hasnt gotten any worse. nor is it spark knock.
i guess it sounds plastic? or some very light metal. it comes from the timing chain side, and its higher up on the motor.
Old Dec 6, 2006 | 09:21 PM
NmexMAX's Avatar
dot dot dot ...
VTC's
Old Dec 7, 2006 | 03:56 AM
platinum03SE
Originally Posted by NmexMAX
VTC's
are those the valves inside the intake manifold?
Old Dec 7, 2006 | 06:18 AM
NmexMAX's Avatar
dot dot dot ...
Old Dec 7, 2006 | 09:06 AM
platinum03SE
lol im new with nissans help me out
user 11122324
42
Jul 18, 2022 03:35 PM
aw11power
Oct 10, 2021 04:57 AM
D Mason
Jun 21, 2016 04:43 AM
uttadms31
Sep 30, 2015 05:24 AM
