Advanced Suspension, Chassis, and Braking Talk about suspension geometry, advanced handling/chassis setup, custom brakes, etc. NOT your basic brake pads and "best drop" Information.
For those with SS lines
Old Dec 10, 2006 | 06:42 PM
!PrjctMax!'s Avatar
I bought a set of brand new SS lines for a 6th gen Max, and when I received the package I didn't exactly know what these valve looking things were...can someone please en-lighten me?
Also, in what way should I bleed my brakes: RR-RL-FR-FL or RR-FL-RL-FR? I've heard both ways from 2 different people. The one that I am familiar with is the first one, but a fellow orger told me that the "criss-cross" method is needed for the 6th gen Max.
Finally, has anyone experienced any problems with SS lines, such as deforming, rubbing on cv boots, and so on?
thanks in advance
Dan
Old Dec 10, 2006 | 08:50 PM
White Shadow's Avatar
Still chugging along...
Those are banjo bolts and copper gaskets. They attach your brake line to the caliper. You bleed them RR-RL-FR-FL.
Old Dec 11, 2006 | 09:45 AM
!PrjctMax!'s Avatar
alright um.......I feel like a total tard for asking this...but is what showed up above just for the front brakes, or for front/rear? Are all the "kits" just for front conversions? I have never really noticed this, so I feel kind of stupid now.
Old Dec 11, 2006 | 09:57 AM
Dubbya's Avatar
VK56 Inside
There are 4 lines there so you have a complete kit for all the way around. Just match up the lengths as you take them off.
Old Dec 11, 2006 | 11:06 AM
BrianV's Avatar
Project,
All Maximas are four line systems, two front, two back. Some cars, mainly, higher-end sports cars with bigger rotors/calipers (multi-piston) carry more lines per brake.
For instance, the 350Z has 6 lines for the front brakes, two for the backs (total of 8 lines), hence why they're more expensive.
Old Dec 11, 2006 | 02:44 PM
!PrjctMax!'s Avatar
aha! gotcha! thanks everyone for the responses and for not bashing me
Old Dec 11, 2006 | 02:55 PM
Larrio Motors's Avatar
Boss Chen Industries
a rule of thumb for bleeding brakes is you want to start on the caliper farthest away from your brake master cylinder. Hence in the case of the maxima: RR, RL, FR, FL
Old Dec 11, 2006 | 04:25 PM
irish44j's Avatar
retired moderator
not according to my Haynes manual
Old Dec 11, 2006 | 05:14 PM
!PrjctMax!'s Avatar
so are you saying to use the criss-cross method? in the end what kind of difference would there be if you bled criss-cross or furthest away from master cylinder?
Old Dec 11, 2006 | 06:07 PM
scrhale's Avatar
This is why we have FSM's
Old Dec 11, 2006 | 09:15 PM
!PrjctMax!'s Avatar
FSM.....?
Old Dec 12, 2006 | 11:06 AM
MrDicks95SE's Avatar
Offset Is Everything.
Originally Posted by !PrjctMax!
FSM.....?
Factory Service Manual.
Old Dec 12, 2006 | 12:05 PM
!PrjctMax!'s Avatar
aha! gotcha, I thought it meant something along those lines but wasn't sure
as for schrale...I did not get a service manual when I got my car, so I don;t have one! jk
Old Dec 12, 2006 | 02:36 PM
You have to buy the service manual, its not given to you.
Although you can download some for free at www.phatg20.net
I'm not sure if they have any 6th gen ones on there yet
Old Dec 12, 2006 | 03:23 PM
Kevlo911's Avatar
Kevlo for President
I thought the FSM said RR FL RL FR
Old Dec 12, 2006 | 03:36 PM
You are correct. Reference BR-9 of FSM/ESM
Old Dec 12, 2006 | 03:51 PM
!PrjctMax!'s Avatar
sweet! thanks guys!
Old Dec 13, 2006 | 08:15 PM
shiftnatredline's Avatar
Godzilla
yeah they look like bleeders..
Old Dec 15, 2006 | 06:30 AM
Mizike's Avatar
Is it worth the investment and time to upgrade to SS lines? Ive already upgraded to the 2K4 brakes, but kept the stock brake lines. Also, using RTP slotted with Hawk HPS pads. Braking power has increased, but Im wondering if replacing the stock lines with SS lines would improve braking power/response that much anyways. Comments appreciated.
Old Dec 18, 2006 | 08:47 AM
Mizike's Avatar
bump please!!
Old Dec 18, 2006 | 09:36 AM
If you have new lines, it's not necessary unless you are installing a BBK. When they are old, you might consider replacing them with SS lines to get a little bit better pedal feel if you want to, but it's not a night and day difference. Mine were 10 years old and I noticed only a slight difference in pedal feel but not stopping distance.
Old Dec 18, 2006 | 09:39 AM
!PrjctMax!'s Avatar
It also minimizes brake fad while under constant pressure---auto-crossing, spirited driving, and so on.
dan
Old Dec 18, 2006 | 02:23 PM
RLW001's Avatar
I downloaded a fsm, what do you use to open an .rar file?
Old Dec 20, 2006 | 12:33 AM
J_Ketzer's Avatar
Try WinRAR, should be downloadable here: http://www.download.com/WinRAR/3000-...=dl&tag=button
It's a "trial" program, but if I recall correctly it doesn't actually make you pay for it when the trial period expires. Either way, it should be good enough to open one FSM .rar.
Apr 16, 2020 05:15 AM
doctorpullit
Dec 12, 2015 09:39 AM
ivorton23
Sep 28, 2015 09:08 PM
Taino14
Sep 24, 2015 02:51 PM
