RPM's
Ok. Normally 5th gear is for saving gas... However, in the Maxima it seems to be geared to go, especially in the 5sp - an auto runs lower RPMs in overdrive than a 5sp in 5th.
As for fuel mileage -- I guess technically his mileage could be better? I imagine it has to do with the type/make of the gear and the gear ratios in the transmission. However, if his is auto I think he gets worse mileage?
Originally posted by 2001SE
i think the 5sp is more economical in the city rathre then the highway, but to tell you the truth i dont understand this either, 5sp are suppose to be more economical
i think the 5sp is more economical in the city rather then the highway . . .
5spd = direct drive. Automagic = torque converter. More efficient to be in direct drive. That means that an automagic with the same gear ratio as a 5spd will output less speed at the wheel because of looses at the torque converter (until it reaches lockup).
Unclejunebug
Apr 2, 2016 05:42 AM
ef9
Oct 4, 2015 08:43 AM
Need help
23
Oct 2, 2015 08:56 AM
