People Running 300zx Calipers & Milled Rotors
If your using the 300zx calipers and milled rotors...are your calipers bolted to the inner or outter side of the hub/spindle.......as in when u bolt them on does the bolt pass thru the caliper or actual car/front end parts/spindle or whatever first
The mounting bolts for the caliper must first pass through the torque member, then bolt into the caliper. This would make the caliper outboard, or on the wheel side of the torque member.
The caliper has the threads in it, not the car. Won't work any other way.
