What The Hell Is Happening With My Car<<<<
Okay guys, so i was on a parking lot today. I was kind of hyper today too...well i was with my friend and we kind of left the parking lot...i wanted to show off so when i got in, turned on my car, turned the steering wheel allt the way to the right and put it in Drive (yeah it's an automatic, ****)...at that point i just slammed on the gas and the tires just burned...so much smoke i couldn't see...well when i stopped and drove off, i put it on drive and it was going to like 2 and a half thousand RPMs but was accelerating very slowly....so i turned the car off...left it for like a minute off and turned it back on....at that point it was okay...what the **** happpened to it? please tell me it's not the transmission.....
Doubt it..
I don't think that it has anything to do with your tranny. So far with my experiences I have noticed that the max can easily get bogged down with excess fuel and that causes it to run like you explained. I am in the process of upgrading my ignition and hopefully a better spark will keep it from doing this.
Yeah, it looks like it went into the safe mode. Not too much to worry about. But don't do that too often. You will drop your tranny if you keep doing that
You may want to reset the ECU just in case by leaving battery unplugged for a few hours...
What the hell is Safe mode?
Re: Doubt it..
what exactly do you plan on upgrading?
plugs, wires?
cuz i'm pretty sure nobody makes an ignition upgrade for our cars.
Re: Re: Doubt it..
Originally posted by My 4DSC
care to expand on that idea?
plugs, wires?
plugs, wires?
Your cars ECM/TCM is monitoring many aspects of your cars sensors, throttle position sensor, engine temperature, outside barometric pressure and temperature, speed sensor, gear selector position, RPM‘s......... Apparently you cars ECM (brain) observed that the car was in drive, engine RPM’s were 6k + and the vehicle speed sensor was telling the ECM that your ground speed was say ten miles an hour, to the ECM this can’t be happening in a normally operating car and it entered safe mode. I would clear the ECM, and stop beating on you car!
Re: Re: Re: Doubt it..
Originally posted by y2kse
My question exactly. What do you plan on upgrading, nvmymax2? Don't be shy. Out with it!
Guess we'll have to wait a little longer to get our hands on a real ignition upgrade for the Max. Hmmmmm. I wonder what the MSD Stacker Ignition will be like?
I guess it depends on the severity of the burn out...
Originally posted by Ironlord
So you're saying you can't do a burnout in this car without it going into safe mode?
Originally posted by Proceedbob
I would have thought most folks could read between the lines, figuring out the computer is programed to ignore this fault condition for a fixed amout of time, otherwise we'd be in fault mode or "Check Engine" light hell. If you think my explination wrong, call a priest.
I was wondering, though, can you tell me like how long we have until safe mode kicks in or to what severity burnout is possible, or anything...
I am guessing it would be pretty hard to quantify. The ECU is montoring so many things and so many factors can come into play. I have spun my tires before and nothing has happened. If it stays that way for a long time, then maybe that would trigger it.
UMD is right, there are hundreds of calculations going on, O2 sensor feed back, fuel trim....est.. If you get a chance ask your dealer to watch the vehicles running parameters on the Nissan Consultant, even better take a ride and you can watch everything running in real time. Just blipping the throttle causes all kinds of mayhem in the emissions feed back loop. (Consultant is Nissans diagnostic computer).
mkaresh
Mar 12, 2018 06:48 PM
RealityCheck
Oct 2, 2015 06:34 PM
Need help
23
Oct 2, 2015 08:56 AM
