Clutch fluid leaking?
Old Mar 3, 2007 | 05:38 PM
hoyshnin's Avatar
Baby's on the Half Tip!
My clutch fluid reservoir goes empty every week and a half or so. I fill it up to the max line (with DOT 3 of course) and 10 days later or so it's all gone. I don't see any leakage from under the hood, would it be back behind the firewall? Has anyone else had a problem with disappearing clutch fluid? What do I do?
Old Mar 3, 2007 | 05:42 PM
MrGone's Avatar
When I did it was my slave cylinder, otherwise pull back the carpet and check
Old Mar 3, 2007 | 05:49 PM
Greeny's Avatar
¯\(°_o)/¯
Put a piece of cardboard under the d-side of the engine bay overnight,this will help you trace the area of the leak...
Old Mar 3, 2007 | 06:26 PM
maxitech's Avatar
If it's clutch fluid that is leaking then it will be simple to diagnose.
The leaky culprit is:
1. The master cylinder
2. Slave cylinder
3. clutch line
Remove the battery and the tray it sits on to check out the slave cylinder. That's what I'll put my money on...
Cliff Clavin's Avatar
Way out West
It's probably the slave or master. I had a slave go out on my first Max. It will get progressively worse if you don't fix it. Mine was barely driveable when I finally fixed it.
Old Mar 3, 2007 | 06:42 PM
Alex_V
My 240sx's master cylinder leaks into the interior of the car. It also has a nice annoying squeak if Im not listening to the radio (rare). My left foot is usually slippery and the carpet wet with clutch fluid every once in a while. But yea its one of the 3 things, the clutch system is very simple.
~Alex
Old Mar 3, 2007 | 06:43 PM
Greeny's Avatar
¯\(°_o)/¯
I have a good used master and slave cylinder for sale..
Old Mar 3, 2007 | 06:57 PM
hoyshnin's Avatar
Yeah, I used to loose fluid a lot slower than I do now. The master cylinder looks fine from under the hood and there is no clutch fluid leaking into the interior. I'll definetely check out the slave cylinder, what should I look for exactly?
Old Mar 3, 2007 | 07:13 PM
MrGone's Avatar
fluid leaking
Old Mar 3, 2007 | 07:20 PM
hoyshnin's Avatar
Originally Posted by MrGone
fluid leaking
Haha, ok. Oh, and the slave cylinder looks pretty cheap from autozone, only $25.
Old Mar 3, 2007 | 07:41 PM
Alex_V
Dont buy an autozone um...hydralic parts. or Alts/starters etc. They fail either quicky or every time they are replaced.
Just get one from the dealer. Isn't that much more expensive and you wont have to redo it 10 times.
My slave cyl from advance is holding up after a whole summers worth of track evens (I wont say the D word when greenies around :P) and subzero winter temps in chicago and its doing fine.
But next time it blows Im buying from the dealer if it blows before its a year old.
~Alex
Old Mar 4, 2007 | 05:40 AM
maxitech's Avatar
Slave cylinder: $22.48 from Brian...internetautomart.com
Old Mar 4, 2007 | 09:35 AM
hoyshnin's Avatar
I didn't see shipping cost info anywhere. How much is shipping?
Old Mar 4, 2007 | 11:43 AM
maxitech's Avatar
It's a bit of a PITA to calculate shipping. Just keep going thru the ordering process and you will get a shipping figure before you have to enter any payment info.
Old Mar 4, 2007 | 12:02 PM
internetautomar's Avatar
mod or sell?
yeah, shipping is based on location.
Old Mar 4, 2007 | 01:02 PM
92 Max's Avatar
If the fluid isn't showing up on the carpet and it doesn't show up on the ground under the car, the slave cylinder is probably leaking into the clutch housing.
Old Mar 4, 2007 | 01:04 PM
hoyshnin's Avatar
I'm thinking that that is probably what is happening then, because I don't see any fluid anywhere (without digging around), it just disappears. Either that, or it's just such a small amount of fluid that I don't see it leaking.
Old Mar 4, 2007 | 01:42 PM
Jon94SE's Avatar
My slave cylinder constantly eats s***. I have to replace it once every 3 months or so. Thing about auto zone hydraulic components is they wear out very quickly but..I have a lifetime warranty on it so everytime it goes bad I just go back and get a new one. It's a bit of a PITA but oh well. I'll eventually go and get a good one that will last though so I don't have to constantly change it out. Edit: by the way alex, that's probably not too good having that brake fluid leaking on the inside, that's pretty corrosive stuff.
Old Mar 5, 2007 | 12:32 AM
Alex_V
Its actually not doing any thing, I keep checking it, but I'm definitely cleaning the carpet when I change the MC.
~Alex
Old Mar 5, 2007 | 04:20 AM
hoyshnin's Avatar
I see two autozone slave cylinders that have lifetime warranties, one brand is Brakeware and one brand is Luk. Which do you have, and would the other one possibly be more reliable?
I also see a slave cylinder kit that they have, is this like a rebuild kit maybe? Would it be worth getting maybe instead of the whole slave cylinder?
Old Mar 5, 2007 | 05:32 AM
Jon94SE's Avatar
Not too sure which one I have right now,didn't pay attention, couldn't tell ya which is better either.
Old Mar 5, 2007 | 07:10 AM
Matt93SE's Avatar
STFU n00b!
I had a LuK clutch several years back. I won't ever buy any of their products again. absolute crapola.
Old Mar 5, 2007 | 07:14 AM
Greeny's Avatar
¯\(°_o)/¯
Pretty much everthing autozone carries is garbage...
You guys that keep getting these idiotzone remans would probably have better luck pulling a used oem slave cylinder from a junkyard car..
Old Mar 5, 2007 | 12:25 PM
Matt93SE's Avatar
STFU n00b!
This was before Autozone carried LuK. I was also told by the tranny shop it was a high quality clutch and would handle the 300hp I was looking at doing with it.
there were many others things that shop flat out lied to me about, and I'll never be going back there again.
Old Mar 10, 2007 | 12:17 PM
hoyshnin's Avatar
OK, I figured it out, it was the master cylinder after all, I have clutch fluid leaking down the clutch pedal, but I didn't notice it until today, thanks all!
Old Mar 11, 2007 | 08:26 PM
Jon94SE's Avatar
Man, I got jinxed by this thread, right after that post my autozone crap cylinder went out again haha. So I went up and got another one for free. And you're probably right about the junkyard theory greenmax, not a bad idea.
Old Mar 12, 2007 | 08:57 AM
mod or sell?
you were jinxed the minute they asked you "what year is the car?"
Mar 12, 2020 12:06 AM
captchaos
Mar 15, 2016 12:18 PM
fastcarny
Oct 12, 2015 07:06 AM
imported_Nismo_max
Sep 20, 2015 08:19 AM
pears
Sep 18, 2015 05:25 AM
