Changed Fuel Filter **Pics**
Old Apr 16, 2007 | 05:57 PM
Hammy
So I decided to to a major tune up of the Max because it was stuttering i would get below half a tank, So I followed all instructions from the FAQ about changing the fuel filter. Everything went smoothly and the car no longer has any problems , but the curiosity came to play when I decided to cut the filter in half to see what I would find. These are the Results:
Sorry for the crappy pics, they were taken with my cellphone.
Has this filter ever been changed, and if it has not what else should change?
Old Apr 16, 2007 | 06:10 PM
willard00's Avatar
honestly, theres no way to tell except asking the old owner. since it got so clogged it was studdering ide say it never was(or hasnt been in a long, long time). you should be good now though. shouldnt need anything else to be changed.
Old Apr 16, 2007 | 06:13 PM
vilmaxima's Avatar
That fuel filter looks like it hasnt been changed, it is VERY dirty. Have you been using fuel injector cleaner? If not would be a good idea to do so.
Old Apr 16, 2007 | 06:14 PM
KsuMax's Avatar
Cheesing away...
here is another view
http://www.motorvate.ca/mvp.php/505
Old Apr 16, 2007 | 06:45 PM
iDuty's Avatar
Please tell us the mileage on your max that this filter came from.
Old Apr 16, 2007 | 07:23 PM
Hammy
I've Only Had the Car 3 weeks.
176,000 and No I have not Run any Fule Injector Cleaner on it yet.
I have Replaced:
Spark Plugs
Fuel Filter
Crankshaft Position Sensor
Camshaft Position Sensor
Pcv Valve
Cleaned Throttle Body.
Am I Missing Anything Else?
Old Apr 16, 2007 | 07:32 PM
Nismo's Avatar
air filter
Old Apr 16, 2007 | 07:33 PM
Hammy
Forgot To Add That Too..
Old Apr 16, 2007 | 07:42 PM
JSMax's Avatar
Sold
clean iacv.
Old Apr 16, 2007 | 07:58 PM
Fr33way™'s Avatar
Wild for Width
Inspect belts, coolant flush.
Old Apr 16, 2007 | 08:11 PM
Hammy
Ok, So My agenda For Tommorow Morning Is
IACV Cleaning
Coolant Flush (Belts Have Been Changed Already, He had the Reciepts dated 2/17/07)
Anything Else?
Old Apr 16, 2007 | 09:07 PM
andrei3333's Avatar
brake fluid flush
have u checked ur front and rear brakes ? the rear calipers MAY get seized on some maximas
If the brakes need replacement Do not touch the brake fluid until u change the pads, NEVER "top-up" break fluid
u have an auto or a manual ? never forget the tranny fluid
Edit: u r lucky u had no trouble with the filter, many people including myself have trouble removing the hoses that are stuck on it with deposits -- i still have my old one that i took out, i should cut it apart and check how bad it was
Did u put a 300z filter on or the OEM max filter ?
Old Apr 16, 2007 | 10:29 PM
Hammy
Also forgot to mention that I Changed all brakes all they way around with just regular stock rotors and Pads.
And I read here to use a 300z filter On it, and did that too.
Here's the Run Down
1995 5 Speed Se
Have Been Runnin 91+
After All This I'm getting About 25mpg Mixed
I have Replaced:
Spark Plugs
Fuel Filter
Pcv Valve
air filter
brake pads and rotors all they way around. (all the brake fluid was changed)
Tommorow IACV, coolant Flush, And I'll be Set?
Old Apr 16, 2007 | 11:20 PM
BunGhoLeo's Avatar
If the fuel filter was neglected that bad, i'd highly suggest changing the transmission oil. I'd recomend Amsoil.
Old Apr 17, 2007 | 08:46 AM
bipolar's Avatar
Thank god for the timing CHAINS!!!
Old Apr 17, 2007 | 08:58 AM
95bluse's Avatar
A point to note is that frequently running your gas tank almost empty increases the amount of crap that gets sucked in. Having said that, I always seem to run low....have to change that habit
Old Apr 17, 2007 | 09:38 AM
andrei3333's Avatar
yeah i heard the same thing from my mech. ^ ^^^ is that because parts of the gas tank rust away from the inside or something ?
i doubt it crap from the gasoline, when i took out my filter there was some nasty stuff in there
Old Apr 17, 2007 | 03:21 PM
m00njal's Avatar
Pardon me, but is there any added benefit of using a 300z fuel filter instead of the stock maxima one?
Old Apr 17, 2007 | 08:45 PM
andrei3333's Avatar
apparently it last longer because its physical size is bigger (thus more filtering media)
Old Apr 18, 2007 | 08:48 AM
boostlogic's Avatar
4th gen
Not sure if it makes a difference, but I was at work yesterday and checked the Z32 filter vs A32, and you can barely blow through the A32 whereas the Z32 is VERY easy to blow through. It made my decision very easy.
Old Apr 18, 2007 | 08:51 AM
andrei3333's Avatar
well that would mean it has LESS or THINNER filtering media would it not ?
Old Apr 18, 2007 | 09:24 AM
phillyzj's Avatar
could easily be more filter area.
Old Apr 18, 2007 | 09:25 AM
andrei3333's Avatar
would that not restrict the flow ?
has anyone cut open a 300z filter ?
Old Apr 19, 2007 | 07:29 PM
aznstormin's Avatar
Is it worth it to get the 300z just because it's bigger? Is it gonna filter more?
And what year 300z filter to get? I don't want to go to the dealer and sound retared getting a 300z filter for the maxima if they ask what year for the filter and I don't know...
Old Apr 19, 2007 | 08:31 PM
WildMax87's Avatar
Dont go to the dealership to get a fuel filter they will scam you badly. Go to Autozone or Advance Auto or some place and near the oil and filters there usually is a book that tells you part numbers thats on the boxes of filters. 1,2, 3 boom your done!!!
Old Apr 19, 2007 | 08:39 PM
andrei3333's Avatar
YES get the 1996 nissan 300z Twin turbo fuel filter FROM nissan, OEM filters are the best for our cars, when i got mine the Maxima fuel filter was $36 canadian while the 300z filter was $32 -- easy decision.
i dont mind paying a little extra for OEM quality, better in the long run
Old Apr 19, 2007 | 08:44 PM
99BlackMaxMS's Avatar
I wouldn't even go there.
www.courtesyparts.com
$12.08 for OEM A32 Fuel Filter
$12.50 for OEM Z32 Fuel Filter
Old Apr 19, 2007 | 08:52 PM
MaxedOut99SE's Avatar
Is there a write up on how to do this?
Old Apr 19, 2007 | 09:02 PM
andrei3333's Avatar
http://web.archive.org/web/200111091...k_service.html
Old Apr 20, 2007 | 07:13 AM
aznstormin's Avatar
Nice, thanks. For an item like this, I don't mind paying a little extra either. Hope the local dealer isn't that much more than Courtesy Nissan [I don't think it should be].
Old Apr 20, 2007 | 10:02 PM
moogotzskillz2's Avatar
SEAFOAM it.....
JoshG
51
Sep 21, 2015 10:41 PM
iamute
Sep 20, 2015 05:22 PM
bumpypickle
Sep 20, 2015 08:22 AM
aminus21
Sep 12, 2015 04:53 PM
sdotcarter
Sep 2, 2015 09:53 PM
