Timing Advancing
Old Apr 19, 2007 | 07:35 PM
Hammy
Timing Advancing
What Exactly is it and what does it do.
Backstory, Car doesnt start right away and my dad said it the timing might need advanced.
Old Apr 20, 2007 | 09:20 AM
heynow's Avatar
details dude, does take longer to crank or what?
Old Apr 20, 2007 | 09:53 AM
pmohr's Avatar
No more Maximas...
Details needed. DIS, no distributor- timing control is in the hands of the ECU, nothing to adjust.
Old Apr 20, 2007 | 11:11 AM
heynow's Avatar
If it takes longer to crank with a warm engine, then it's the ECTS (Electronic Coolant Temperature Senosr)
Old Apr 20, 2007 | 12:23 PM
NmexMAX's Avatar
dot dot dot ...
Or MAF voltage.
Old Apr 20, 2007 | 01:25 PM
L0R1DA's Avatar
Please specify exactly what happens that is problematic and when does it happen.
Old Apr 20, 2007 | 01:28 PM
NmexMAX's Avatar
dot dot dot ...
Timing may have skipped a tooth, but that would only happen if you've done some major work on it recently. i.e replace water pump, timing chain/sprockets etc.
Old Apr 20, 2007 | 03:38 PM
nismology's Avatar
There are MANY potential reasons for hard starts. We need more info vehicle maintenance history, mileage, more detailed description of when it happens, etc.
Old Apr 21, 2007 | 08:35 AM
Hammy
Sorry bout the long *** wait.
175xxx Miles
I've changed everything under sun
Including 2 Camshaft position sensors, crank shaft sensors
Fuel filter, starter, PCV valve, Air Filter.
Old Apr 21, 2007 | 08:37 AM
Hammy
And it only happens when warm, Probably going to chage fuel pump this weekend.
Old Apr 21, 2007 | 09:45 AM
Suzie (v)Q's Avatar
Fast & Furry-ous
I wouldn't suspect the fuel pump just yet. Is the CEL(check engine light) on or been on? Have you gotten any codes? Has there been any stalling or hesitation? And odd as this may sound; Does your radiator fan act normally, or does it start early/stay on a long time/not turn on?
___
JLD
Old Apr 21, 2007 | 12:14 PM
Hammy
the radiator Is new, both fan are also new, and run when they are supposed to, the was stallin and hesitation at the begining before the fuel filter change, after that it has dispappeared.
Old Apr 21, 2007 | 12:33 PM
TurTLe*'s Avatar
i think you need to stop throwing parts at it and just have a sit down and think about what exactly are your problems and what are your most likely problems down to the rare rare problems. seems like you went with the cheaper parts first but think before you act to possible save you money
you timing probaly is the least likely thing
Old Apr 21, 2007 | 03:31 PM
nismology's Avatar
Like someone else mentioned, a bad engine coolant temp sensor (ECTS) can cause this.
Old Apr 21, 2007 | 03:34 PM
Suzie (v)Q's Avatar
Fast & Furry-ous
Ok, just wondering, since I'm fighting a similar problem which is currently presenting itself as the Engine Coolant Temp Sensor(ECT(S)). Stalls/dies (or tries to) when mostly warmed up in my case. Last night it even gave a hard time starting after it had been driven a bit. Between the symtoms(which seem common to quite a few causes), and that the fan would sometimes start up WAY early, I went after the ECT. I pulled the old one and it checked marginal for air/room temp and ok for warm(~120*F), but for hot it freaked(jumped around until it finally just read open). As this has been an intermittent problem I won't know if that was the true cause for a while, but for you it's something to look at.
You didn't mention anything about the CEL/codes...any indications?
___
JLD
Old Apr 21, 2007 | 10:31 PM
heynow's Avatar
yeah, i recently changed my ECTS. I used to need to crank a while longer if the car sat for like 30 mins-1hr after being driven. Now it starts up like that! (snaps fingers) But the fans DO come on much more/earlier than usual.
Ben2003GLE
31
Jul 17, 2016 08:13 AM
kmitchel
Oct 28, 2015 09:46 AM
Starrider
Sep 17, 2015 07:26 AM
rbaker100
Aug 31, 2015 11:09 AM
305head
Aug 26, 2015 09:03 PM
