Anybody have Haynes or Chilton repair manual in PDF
Does anyone here have those manuals in PDF form? I need one to replace the valve cover gasket on my Max. The FSM is useless to me. I found nothing in it about the valve cover.
Originally Posted by dfswartz
I have the 95-99 Nissan service manual on cd.
Originally Posted by nismology
A quick glance through the FSM produced not only the tightening torque specifications, but the tightening sequence and where to apply the RTV silicone sealant.
Goto autozone, ask for this: http://www.autozone.com/in_our_stores/znet.htm
I have Mitchell repair manuals on DVDs.
Jae
Jae
Got to check that out. Yar.
of ots the front valve cover itsall 10mm bolts and has a 1 piece rubber gasket that stays in place you do not need RTV start in the center and work your way out loosening the bolts you do ot need to remove anything else but the wiring harness for the coils you can leave those screwed in if you please becareful when tightening , thoug just a slight tourqe down will do fine
Originally Posted by slinky87
you do not need RTV
The FSM is useless but you want a chiltons or haynes? wtf...
I guess he used ctrl+f to search text even tho the 4th gen pdf's are images
Index > him
tarun900
19
Dec 20, 2021 06:57 PM
mkaresh
Mar 12, 2018 06:48 PM
