Tranny leak
Old Apr 29, 2007 | 05:43 AM
maxima94ever's Avatar
Tranny leak
Can anybody tell me if putting a stop leak fluid in my auto tranny would do more harm then good ? I dont have the cash to take care of it right now it leaks only when car gets hot, ive been driving for a while i park in my garage and later i find a puddle. Please help. Thank you J. Alejandro
Old Apr 29, 2007 | 07:05 AM
Matt93SE's Avatar
STFU n00b!
the stop leak stuff usually just makes problems worse in the long run. I'd advise you to stay away from it.
Try looking under your car and see if you can figure out where the leak is. often it's something simple, like a $5 hose that's leaking at a fitting or an axle seal. the seal itself is about $15, and it'll take you an hour to replace.
Old Apr 29, 2007 | 07:39 AM
internetautomar's Avatar
mod or sell?
unless it's the front pump seal leaking. they , as matt said, are all easy to get at and fairly cheap to fix.
most of the gaskets/seals will cost you LESS than a bottle of stop leak.
Old Apr 29, 2007 | 09:48 AM
I'll check on it i'll have to have the engine n tranny washed first tosee were the problem is. Thanks for the advice.
Old Apr 29, 2007 | 04:13 PM
bvtran's Avatar
94c Big Max
where is the leak? Have you found out that exact location? A very common place for leak to occur is around the seal where the passenger axle goes into the tranny.
Old Apr 29, 2007 | 04:56 PM
I believe its coming from behind the tranny, have to clean it first to look.
Old Apr 29, 2007 | 10:06 PM
Matt93SE's Avatar
STFU n00b!
if it looks like it's behind the tranny, then it's very likely an axle seal leaking (it's near the back of it), or the "oil pan" gasket on the top of the tranny is leaking.
Old May 1, 2007 | 11:39 AM
It looks to be from the back of tranny,Thanks everyone.
litch
123
Jan 4, 2024 07:01 PM
aw11power
Oct 10, 2021 04:57 AM
fx4five
Oct 18, 2015 06:57 PM
fx4five
Oct 1, 2015 04:58 AM
Socalstillen
Sep 20, 2015 11:46 PM
