Where is the MAP sensor?
Old May 1, 2007 | 10:10 AM
Jellyfishian's Avatar
Difficult is NOT impossible!
Hey guys I have a MAP sensor code, that wont go away even after being cleared. So I'm going to make sure its connected right, and then replace it if it just gave up on life. I looked in the FSM but that offered little help to its location. Thanks guys, pics help too! After I fix this the car is going up for sale
Old May 1, 2007 | 10:28 AM
Scruit's Avatar
U wanna try me young boy?
MAP sensor? I thouht our cars had a MAF sensor instead..?
Old May 1, 2007 | 10:34 AM
Kevlo911's Avatar
Kevlo for President
Was it the BARO/Boost/Map sensor code? What code was it(XXXX)?
Old May 1, 2007 | 12:35 PM
Apparition's Avatar
Ichiban King
The MAP sensor is where you want it to be..
Old May 1, 2007 | 02:40 PM
Don Mazimo's Avatar
It it's the MAF sensor then it is the box located on the air intake. It has a filament that measures the temperature and helps determine air to fuel mixture... mmmmm ... yeah that sounds right.
Old May 1, 2007 | 03:25 PM
slinky87's Avatar
check towards the front next to coolant pipes follow the vacum lines one says boost sensor thats the one a MAP sensor has nothing to do with temp it measures vacum changes in the manifold to measure how much air fuel it should be putting out butnissan puts them there like a fail safe in case the MAF sensor ever fails but its pretty much invisible otherwise to the PCM so just make sure your connections are are tight on it and the vac line is not damaged or cracked
Old May 1, 2007 | 04:11 PM
Apparition's Avatar
Ichiban King
Wrong, thats what the IAT sensor is for.. The MAF is just what the acronym stands for, Mass Air Flow sensor. It measures air input via volts (0-5v) and blah blah this is over your head I imagine.
WE DO NOT HAVE MAP SENSORS, YOU ONLY WISH YOU DID..
Old May 1, 2007 | 04:23 PM
Thanks guys, it was the sensor that said boost on it. Must have forgotten to plug it back in after changing the alternator. Reset ECU again and code and CEL is gone!
Old May 1, 2007 | 04:24 PM
slinky87's Avatar
glad i could help
Old Feb 20, 2008 | 09:19 AM
spalmer's Avatar
map sensor
If they do not have map sensors, why does mine show the code and why can you buy one for it?....for $250 ...ouch.
TallTom
57
Oct 14, 2025 05:16 PM
my03maxima
Jul 28, 2024 07:40 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
