Will my wheels clear a BBK ?? PICS !!
Well this is always a question that no-one can answer.
Will my Wheels clear a possible BBK ?? 300ZX Calipers and either Maxima rotors or Cobra Rotors.
18" Racing Hart C5's
I measured 5 1/2" out from the Center of the wheel, and measured the space between the spoke and the rotor, and theres about 2 1/4", NOT 2 1/2"
Where did you get that 2.5" #? Matt's site? If so you will need an additional 10mm for my stuff to fit.
Use spacers. Or go with my stuff and Q45 calipers or J30 calipers. They use 2 piston calipers that are the inside. Freeing up alot more clearance inbetween the caliper/wheel.
http://forums.maxima.org/showthread.php?t=468945
Well off hand, you will have the best chance with Matt's kit if you can get it.
Although did you measure where the calipers are OR where the caliper WILL be once you put on the relocation bracket? Your wheel spokes look like they turn in as it goes to the outside.
Not too sure why you think using the Q or J rotor ISN'T doing it right. I think they are a great alternative to the 4-pistion. IMHO most of the great braking is from the torque arm advantage of moving the caliper out. Not necessarily the 4-piston caliper.
Originally Posted by Jeff92se
Although did you measure where the calipers are OR where the caliper WILL be once you put on the relocation bracket? Your wheel spokes look like they turn in as it goes to the outside..
Is that the right part to measure
-matt
Yes that's right. BUT that's where your caliper is NOW. With the brackets, the caliper will be moved out further to accomodate the larger rotor. What's where the caliper WILL be. Use your same measurement method but measure from where the caliper will be after it's moved out. Not where it sits currently.
So my only option is to order all the parts, $600-$700 worth of parts, and install everything, and it my wheels dont fit them im outa luck ?? I wanna make 100% sure that this will work before I invest. ya know ??
-matt
-matt
Those wheels clear the calipers on the 300zx even with the bracket accomodating the bigger Cobra rotors, so I don't see why you would have a problem. If you have just a slight clearance issue, you could sand off part of the Nissan lettering.
No. I'm trying to get to measure from the right spot for the best guess possible.
Where your caliper sits NOW isn't where they will be when the bbk is on. Therefore you have to measure the clearance where the caliper WILL be. Not where it's at now. With either kit, the caliper will be moved out another 1.5 - 2". I'm **** w/ editing photos but see this pic. Maybe it will help. Notice the red:
-matt
-matt
Originally Posted by samito
hey matty you can check my bbk out monday when i see you to pick up the stillen lip--i have blehmco kit with j30 and it stop hard
See if you can put your wheel on his combo and measure the clearance from the top of the spoke.
Ok Matt, as far as your rims having enough diameter to fit the BBK; they're fine, I'm rockin 17's with my Cobra/Z32 BBK.
Now for the rotor to spoke clearence, I measured about 3" which leaves me with about a 1/4" gap from the back of the spoke to the caliper.
Looking at your measurements it looks like you may need spacers to fit the Z32's on there. Not sure when it comes to the Q45's but I'd imagine they would fit with your clearence. HTH
What spacers should I order if I do decide to go with the Z32 Calipers ?? 5mm, 10mm ??
I figure, If I do a BBK, might as well do it right, right ??
-matt
-matt
Well that would depend on how much space you need. If you are going to use spacers, you should look at the space between your tire and fender. Are your wheels pretty flush right now? A spacer may push the wheel out a bit and make it look nice and flush, or it may push it out too much and make it look odd.
-matt
-matt
Ok, one thing to take into account is that your clearences will be different depending on what rotors you decide to use. The Cobra rotors actually eat up about 3/8" of space because the rotor hat is shorter (this moves the rotor center out towards the wheel about 3/8"). This is why the caliper has to be spaced off the mounting tabs like so:
Doubt this is the case with the 12.6" maxima rotors but I have no experience with those. So looking at the clearences you posted and going with the Cobra rotors, 2 1/4 - 3/8 = 1 7/8 which is your clearence after the rotor is installed. Then using my clearences, 3 - 1 7/8 = 1 1/8 which is about the thickness of spacer you would probably want to run. Now, another thing to take into account is the spoke design of your rims. If the spokes 'dish' outward traveling up the radius like my rims:
then you may gain clearence because the caliper also gets repositioned ~2" up the radius as well. This was excatly the case when I switched from the Z32 rotors to the Cobra rotors. I had a total clearence of ~1/8 behind the spokes with the Z32 rotors and actually gained another 1/8 because of my spoke design.
As always, let me know if you have any other questions or if I didn't explain anything clearly enough. Or even email me or give me a call.
ballerchris510
Sep 10, 2015 09:35 PM
