Alarm Remote / Corners (near headlights) don't work
Old May 10, 2007 | 12:46 PM
GREENlight's Avatar
Has anyone ever had this problem before? All of a sudden, my remote for my car stopped working and my corner lights stopped working. Help
Old May 10, 2007 | 12:51 PM
Digitized's Avatar
Try reprogramming the KEY FOB .. it should work..
as in terms of the corner lights... check fuse or bulbs ( never know )
Old May 15, 2007 | 09:06 AM
GREENlight's Avatar
I tried reprogramming. When I took the key in and out of the ignition, my lights don't even blink.
Old May 15, 2007 | 09:53 AM
EteRnity059's Avatar
Boosted?....
Did you do a the corner light mod? If so, you harness or connector might have melted. I had the same thing happen to me a while back. As far as your Alarm, you should follow the owner's manual to reprogram. There is a sequence that you need to follow. If that doesn't work, check the battery in your remote.
Old May 24, 2007 | 10:09 AM
GREENlight's Avatar
I finally got the remote to work. I pulled out just about every fuse and plugged them back in. After that it worked. I guess one of them was loose. Still trying to get my corner lights working. I took both of them out to check for any melting and everything was fine.
Old May 24, 2007 | 10:57 AM
Boosted?....
Did you check you main fuses in the engine bay? Relays maybe?
ah2002
Mar 9, 2016 01:42 PM
jerrod99_se-l
Aug 27, 2015 08:27 PM
wingsfan24
Aug 15, 2015 07:35 PM
maximaham
Aug 7, 2015 01:11 PM
kenc15
Aug 5, 2015 08:29 AM
