Problem/question with centerbore
Old May 15, 2007 | 04:44 AM
Fasteddie01's Avatar
I am having a same problem with some rims off a stock Mazda 626. They had 67 mm centerbore, but the hub cap of the rim was only about 55mm. This is at the outer edge and didn't cause a problem in front, but the rear wheel grease caps stick out about 1/2 inc or more and run into the rim 's hub cap hole. I haven't decided whether to Dremel out the rims or just look for diff ones, but I need to find out if there are press in hub caps that are about 65- 66 mm if I do that. Anyone know where I can find something like that ?
I got the centerbore info from a link here, but it didn't mention the rear grease cap being so protruding. I never thought to check when I bought the rims, since the website showed they were only 1mm larger than Max.
Old May 15, 2007 | 05:11 AM
phenryiv1's Avatar
Mod her. Ate her.
I made this its own thread. He had obviously searched, based on the thread that it was in. Please don't club him about searching.
Old May 15, 2007 | 06:24 AM
Fr33way™'s Avatar
Wild for Width
Can you use spacers to clear that caps in the rear?
I would put the wheels up for sale while you look for a solution unless you are attatched to them already.
Old May 15, 2007 | 11:28 AM
Nope, They're held away about 20-30mm; not worth the risk from what everyone says about spacers, new lugs etc. Thanks for the thought. I'll probably sell, but here in Halifax there's not a big market in this size.
J2FRESH
Wheels/Tires
37
May 14, 2012 10:45 AM
Cutler
Wheels/Tires
Sep 10, 2008 12:03 PM
Hamy
Tires and Wheels
Aug 30, 2004 07:44 AM
stevay
Tires and Wheels
Jul 23, 2004 10:16 PM
philpoe
Jan 3, 2002 09:05 AM
