CV Shaft help
Old May 29, 2007 | 04:29 PM
Xzecution'R's Avatar
CV Shaft help
is there a procedure how to get the driver's side LSD axle on? because mine went in and clicked but it was sticking out too far and didn't seal to the tranny. thanx pics would be great too
Old May 29, 2007 | 07:18 PM
KRRZ350's Avatar
Rubber mallet to tap it in, and if it still doesn't tap in all the way inspect/replace the little c-clip, technically the procedure is to replace the clip every time, but I've never had a problem........
Old May 29, 2007 | 10:05 PM
it's brand new
Old May 29, 2007 | 10:09 PM
Bobo's Avatar
Is the seal brand new or the retaining clip?
Assuming the seal is in properly, you should be able to push the drive axle in, although you said you heard the click.
Old May 30, 2007 | 05:43 AM
KRRZ350's Avatar
Did you compare the old axle with the new?
Old May 30, 2007 | 06:22 AM
oldngivout's Avatar
Willing to learn
In my experience, the LSD axle is rather difficult to install, but will go in properly with a little finesse. The two sets of splines must be engaged separately. After the first set is seated, continue to turn and gently push on the axle until you can feel the second set engage. Then use a mallet or something to finish seating the axle. As usual, it will be a satisfying clunk when it is seated all the way home.
James92SE
142
Jan 2, 2024 09:23 AM
rbarnes
Dec 31, 2015 06:29 PM
BiggRoosta
Sep 21, 2015 12:25 AM
conansriver
Sep 11, 2015 10:26 AM
