'96 Max, replaced struts, now odd noise while turning wheel
Hi,
I've finally got around to replacing my front struts after 190K. I replaced the OEMs with Monroes Sensitrak as the price was right. Anyhow I put everything together and now hear an odd sound when turning the steering wheel from side to side. I've also replaced the strut bearing while I was at it. The car rides fine, no noises going over bumps, just when turning the steering wheel as when going around a corner. (I had the wheels aligned a few hours ago.)
Any ideas for a fix?
Thanks,
Chris....
PS. I did check out this forum's suspension guides, but most deal with lowering and the accompanied noises.
Thanks,
Chris....
Check lower end links, and tie rods to see if they have too much play, or are busted. These are usually noticed after the change of struts. Most people swap out the struts because that's the easiest thing to point out, and it usually needs to be replaced anyway, but most links are neglected.
Well, I didn't have the noise before I replaced the struts. The alignment technician checked for components for wear, wheel free play, etc., and pronounced it good to go with the alignment.
I wandering though, I've torqued the top strut nut while the car was still up on the jacks, would it make a difference it the car was on the ground prior to torquing those nuts? I suppose I can retorque if it makes a difference.
FINALLY someone with the monroe sensitrack struts. ive been staring at the canadian tire flyer for about 3 months now, its got the buy one second half price deal on everything monroe.
hows the ride compared to stock struts ? u kept the oem springs right ?
did u replace the rear shocks as well or kept oem ?
sorry i cant help u with ur noise problem tho
trasmadean
Feb 1, 2017 08:20 PM
FanaticMadMax
Aug 10, 2015 08:55 PM
kirkhilles
Aug 8, 2015 10:53 AM
