Methanol injection on a 6th gen?
Old Jun 14, 2007 | 03:14 PM
My-Body-Is-Ready's Avatar
My engine gets HOT AS HELL!! after a short drive, i pop my hood and the intake is already freakin hot... Will methanol injection work for a non boosted car? or is there just something wrong with my car? Any other 6th genners have this problem????
Old Jun 14, 2007 | 03:16 PM
mtrai760's Avatar
'Trynna' is not a word
You will lose power. It is normal for it to get hot under the hood, unless your temp gauge starts rising you are fine.
Old Jun 14, 2007 | 03:44 PM
How will i love power though if it suppose to get cooler? care to explain? i dont know what it is but it seems to be hotter than before... or maybe im going crazy...
Old Jun 14, 2007 | 03:49 PM
SilverMax_04's Avatar
Correct. Look at the temperature gauge to see if your engine is overheating.
These engines were designe to run hot -- and are not fully efficient until the engine reaches normal operating temperature.
Methanol is a nasty product that eats many rubbers and plastics. I would stay away from it.
Old Jun 14, 2007 | 04:22 PM
Hilbe's Avatar
Just get the phenolic spacers sold at www.nissanworks.com. Should lower your temps 40 degrees....
Old Jun 14, 2007 | 04:23 PM
kamski's Avatar
.org extraordinaire
Amen to that brother amen.
Kamski
Old Jun 14, 2007 | 04:49 PM
Machinist's Avatar
It's your Headers Phil, they are making the under hood temp higher
Old Jun 14, 2007 | 05:03 PM
already have homey....
damn... when im just standing on the side of my car i feel a lot of warm air it made me scared
Old Jun 14, 2007 | 05:08 PM
DeusExMaxima's Avatar
Well if we all can decide on a hood with either venting or small scoop, perhaps then the underhood temp will drop. In the mean time, make my cold air box and ur power should be better.
Old Jun 14, 2007 | 05:11 PM
NmexMAX's Avatar
dot dot dot ...
W/ headers and a HAI, my IAT's weren't much above ambient (2-4*)whenever my speed was anywhere above 10MPH. When at a stop, they were anywhere between 20-25* above ambient.
Old Jun 14, 2007 | 05:41 PM
chernmax's Avatar
Nations 1st 6th Gen Turbo
I have headers and even before installing the IM spacer kit from NissanWorks.com (awesome), my engine did not run hotter than normal...
If your temp gauge is running higher then half way, you may want to consider other possibilities as to your over-temp problem...
Old Jun 14, 2007 | 05:51 PM
mtrai760's Avatar
Methonal/water injection is used to cool down air heated up by forced induction. The point is to cool down the air so you can run more boost (more power) without detonating and destroying the engine. Let's say you were running at 6psi on a turbocharger, and had no problems with detonation. Now you add meth injection, and keep the boost level the same. The car will make less power. There has to be something to make up for the loss of power (boost) and being NA, it will only cause you to lose power, and will not serve to cool the car at all, that is not its purpose. Hope this makes sense.
Old Jun 14, 2007 | 06:00 PM
NmexMAX's Avatar
dot dot dot ...
The OP never sated his temp gauge read hotter, just seat of the pants, qualitative observation.
The temp gauge gets and points to it's 'normal' temp when the coolant temperature is @ or above 160*F, and starts moving after ~210 -215*F. So the coolant temp can be between 160 and 210, and STILL point in the exact same spot.
If it's still unclear, a could have it sorted out.
Old Jun 14, 2007 | 06:49 PM
thanks for the explanation!
also sometimes while im driving i feel like the heat turns on under the dash. Any1 else get this?
Old Jun 14, 2007 | 10:08 PM
maX5's Avatar
LOL Phil, you need a vacation bro.
Old Jun 15, 2007 | 08:26 AM
hey!! im going to LA and hawaii in a few weeks so cmon admir you cant see me!!! and we arent in your stomping grounds any more so you can do anything to me mr moderator...
Old Jun 15, 2007 | 09:09 AM
hmr1979's Avatar
That advice is on point.
Old Jun 16, 2007 | 11:12 AM
madmik's Avatar
Yes. My dealer said other customers reported the same issue. Dealer checked for codes on the computer but found none.
Check the rear hood seal. If not tight, it could let hot air out and back in the car through the fan intake vent.
Get on a dyno and check if A/F is too lean. Can cause exhaust/cats to run much hotter.
Old Jun 16, 2007 | 12:57 PM
NmexMAX's Avatar
dot dot dot ...
He already has.
http://forums.maxima.org/showthread.php?t=525075
imported_Nismo_max
Sep 21, 2015 07:24 PM
Max139617
Sep 20, 2015 07:09 PM
hot04
Sep 18, 2015 06:14 AM
240tomax
Sep 13, 2015 03:28 PM
