BBK Upgrade Question?
Old Jun 25, 2007 | 05:10 AM
JoesRedMax's Avatar
Hey guys, I know this was answered a while back but I can't find the origional post. I am thinking about buying the 4 piston Wilwood brake upgrade. I want to know what size spacers I need to get to use these brakes with the stock 18" wheels.
Old Jun 25, 2007 | 01:55 PM
eK9aT10pSi's Avatar
i believe 5mm spacers will do the trick.
Old Jun 25, 2007 | 01:58 PM
!PrjctMax!'s Avatar
or you can get the 6POT calipers and not have to get spacers...
$30 spacers? < few hundred dollars more for a 6POT kit
Old Jun 27, 2007 | 07:38 AM
xoomer.com's Avatar
I Donate! Why Don't You?
NOT TRUE. The 6 piston calipers don't clear the stock 18" even with 8mm spacers.
Here are the threads
http://forums.maxima.org/showthread.php?t=495272
http://forums.maxima.org/showthread.php?t=495271
http://forums.maxima.org/showthread.php?t=493524
Old Jun 27, 2007 | 07:42 AM
!PrjctMax!'s Avatar
Pszepraszam, I could have sworn that Kamski said the 4POT DO NOT and the 6POT DO CLEAR, but my bad yo
Old Jun 27, 2007 | 07:54 AM
xoomer.com's Avatar
I understand, Kamski did say somewhere that the 6 POT were smaller and should fit just fine. They are not. I tried stock 18s and they didn't fit with 8 mm. I have 10mm spacers on my car so at some point I'll ask my bro to try it on again.
Old Jun 27, 2007 | 09:21 PM
Ankit69's Avatar
so will 10mm spacers clear the stock rim ? 18"
Old Jun 29, 2007 | 07:00 AM
xoomer.com's Avatar
i'd have to verify it this weekend, provided my bro is around.
Old Jun 29, 2007 | 11:50 AM
kamski's Avatar
.org extraordinaire
Yes I did, I was told by the guy that makes the kit that the 6Pot would clear easily but the 4Pot would need the spacers (bigger outer body). There are two types the SL6 and SL6R 6 pot calipers, the R version is the reduced sized one that was apparantly supposed to fit. But based on Xoomers experience it did not. Unelss he got the SL6 and not the SL6R.
I still only got the 4Pot and I use a 5mm spacer with my stock rims (very seldom). So that I could match it up to a rear kit.
Kamski
BkGreen97
Apr 2, 2016 05:47 AM
pears
Sep 18, 2015 05:25 AM
