Fun With Starters
Old Jul 7, 2007 | 07:24 PM
Jon94SE's Avatar
Fun With Starters
For quite some time now my starter had been just free spinning the first three or four times the key was turned but would eventually work. Recently it was getting to the point where it would take almost ten tries before it would actually grab. So I went to Autozone ( yeah I know ) because I work there and today was %30 off for employees. Took me about five minutes to get it in there and when I tried to start it, nothing. I had voltage to the positive post on the starter. And the solenoid switch connector had voltage in the start position. Right away I assumed it was a bad starter. I brought it back to the store and put it on the tester. It came on right away and tested good. Then I put it back in the car again, and still nothing. Checked all my fuses, tried adding another ground to the starter ect. No dice. Again I brought it back up there and tested it again, this time it failed. I had to drive twenty minutes back out to a different Autozone to get another one. I put that one in the car and it fired right up. The next time I went to start it, it just clicked and clicked untill I finally rolled the car a bit and let the clutch out to move the motor, now it's not having problems. I'm wondering could the flywheel be an issue? It did look a little beat up from the other starter but not too bad...why would it just click with the motor in certain positions?
Old Jul 7, 2007 | 07:49 PM
goon9's Avatar
Mine started doing that, it turned out to be dirty and corroded connections.
Old Jul 7, 2007 | 08:22 PM
mikekantor's Avatar
Your battery got low from all the start attempts on the bad starter, thats why you just hear the relay click and nothing else happens. Do a decent highway run (like 30 mins) and then see if you have any problems after that.
Old Jul 7, 2007 | 10:03 PM
Tquick's Avatar
If that doesn't do it, pull the cables off the battery, and make sure the cable ends, and battery terminals are nice and clean, then put the ends back on, and make sure they are tight. It might also pay to make sure the positive connection at the starter is clean and tight, and same for the ground connection at the engine. A loose or dirty connection at any of these points can cause the problems you are having.
Old Jul 11, 2007 | 11:49 AM
Darkwing48's Avatar
I've could have sworn there was an Autozone commercial like this
Old Jul 14, 2007 | 06:48 PM
Jon94SE's Avatar
Okay, so I'm still having some trouble with the new starter. Every other time I drive it, it just clicks and doesn't want to start. If I roll the car back just a little bit and move the motor and then try it fires right up. That doesn't really make any sense to me since the flywheel is okay and it never grinds or anything. I recently cleaned the connections and made sure everything was tight. The only thing I haven't really checked is the mating surface between the tranny and the starter. Could it just be a ground issue because there's some crap between them and it's dirty maybe? Does it help to run an extra ground from the casing to the battery or something? I plan on checking that soon but I've been busy and tired from work. I've heard people have had issue with that though.
Old Jul 14, 2007 | 08:02 PM
internetautomar's Avatar
mod or sell?
Crazy as it sounds (to me)
check your mounts. maybe the motor is shifting enough to misalign the starter
Old Jul 14, 2007 | 09:36 PM
emseegusto's Avatar
i have replaced 4 starters on my 90 maxima within the last 2 years
Old Jul 14, 2007 | 09:46 PM
Jon94SE's Avatar
Right, but the starter is bolted to the tranny/motor so it would move with it.
Old Jul 15, 2007 | 05:27 AM
mod or sell?
but the wiring can get pulled...
wierder things have happened.
Old Jul 15, 2007 | 01:19 PM
gapboi210's Avatar
I have had several issues with Autozone starters. You may want to trying swapping it out again.
Old Jul 15, 2007 | 08:30 PM
Jon94SE's Avatar
Probably end up having to....
BobTX10
Oct 7, 2015 08:43 AM
maxima297
Sep 30, 2015 03:32 PM
msellas
Sep 23, 2015 09:16 PM
homewrecker
Sep 23, 2015 03:41 AM
Pixel
Sep 15, 2015 05:53 AM
