The Max is having a hard time starting
Old Jul 7, 2007 | 11:36 PM
Noslen's Avatar
The max used to start immediately when i turn the key, but now it seem to not want to start without a little gas and an extra split second of turning the key longer.
any suggestions guys?
Old Jul 7, 2007 | 11:55 PM
d3v0's Avatar
mine does that too, i replaced the starter, but the starter wasnt new, its refurbished but, i think it might be my fuel pump.
Old Jul 8, 2007 | 04:33 PM
abomb1987's Avatar
Does this happen when hot or cold
it could be
ECTS
fuel filter
bad tps
or the infamos PCV valve
Old Jul 9, 2007 | 10:17 AM
eilison's Avatar
I also have similar problem recently. And I think mine is worse.
Sometimes when I turned the key all the way to start the car. Nothing happens! However if I put the key in the last position(not sure about the name, maybe ignition slot) for a while, say 3 or 5 seconds before I try again, it would start.
Seems like it happens more likely when it is hot and my car has been sitting in direct sunshine for a few hours. I live in southern California where it is sizzling hot these days. Nontheless, it happened in parking structure too. So I don't think hot temperature is the only key factor.
I installed a brand new starter six months ago. So starter problem is off the table in this issue.
I don't have any problem starting up in every morning(e.g. cold start).
I had my battery tested at Autozone, and it is good.
Any suggestions?
Thanks in advance!
eilison
Old Jul 9, 2007 | 11:06 AM
sky jumper
replace your fuel filter if you have not done so. not enough fuel flow/pressure for cold start.
this also happens when you get close to an empty gas tank.
if that doesn't fix it, check your plugs.
after that there's a long list of sensors & other stuff. but first things first.
Old Jul 9, 2007 | 12:26 PM
d3v0's Avatar
it could be
ECTS
fuel filter
bad tps
it happens when its cold
kjlouis
Nov 24, 2018 06:09 AM
02PearlSE
Oct 7, 2015 02:12 AM
MaximaRaj
27
Oct 2, 2015 07:31 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
Balkins
Aug 12, 2015 06:39 AM
