Reseting ECU
Old Jul 24, 2007 | 03:52 PM
bigwee's Avatar
Reseting ECU
I just replaced my MAF with another and heard I need to reset the ECU. I had searched and all that shows up is http://www.technosquareinc.com/350reset.htm and it doesnt seem to work on my car, maybe Im doing it wrong. But some say that it only works on 2k3 and up. If so how do we reset the ECU.
Also I noticed that my car still hesitates accelerating, is this because the ECU hasnt been reset? thanks
Old Jul 24, 2007 | 05:43 PM
NmexMAX's Avatar
dot dot dot ...
http://forums.maxima.org/showthread.php?t=104931
Old Jul 25, 2007 | 06:20 AM
bigwee's Avatar
Alright I just did the reseting the check engine light but Im still having the hesitation when I accelerate. Any ideas?
Old Jul 25, 2007 | 06:21 AM
NmexMAX's Avatar
dot dot dot ...
Retrieve the code Read a little harder mmmk?
Old Jul 25, 2007 | 07:19 AM
bigwee's Avatar
I already know what codes I have. I had 3 which were the maf sensor, knock sensor and rear o2 sensor with the o2 sensor being the only one not replaced yet. I was just reading that sence I replaced the maf with another one that I need to reset the ecu, and thats what I have been asking about.
Old Jul 25, 2007 | 08:17 AM
NmexMAX's Avatar
dot dot dot ...
Maybe you still have a defective MAF. Did you buy it used or new? Also, you can check the voltage spec on the MAF as well. Also try checking the MAF harness and connector.
Old Jul 25, 2007 | 10:20 AM
andrei3333's Avatar
oh and BTW just so u know its NOT the rear o2 causing you problems
Old Jul 25, 2007 | 11:32 AM
bigwee's Avatar
I noticed a jump in my gas mileage when I changed it so I dont know if it is defective, could that happen? Oh and it was used.
Old Jul 27, 2007 | 02:25 AM
kzoosho's Avatar
Would reseting the ecu help if you have upgraded your car i.e. a turbo?
Old Jul 27, 2007 | 02:34 PM
NmexMAX's Avatar
dot dot dot ...
If you’ve got a turbo, the last software item you should be thinking of is an ECU reset.
Check this forum for more details.
http://forums.maxima.org/forumdisplay.php?f=53
gigabyte
Jan 6, 2017 06:05 PM
Omar Abdurrahman Siddiqi
Aug 26, 2016 05:18 PM
BLACKKILA.GTR
Sep 29, 2015 11:23 AM
220k+ A32
Sep 22, 2015 03:08 PM
Colossus
Sep 9, 2015 05:46 AM
