Is my starter the problem? (video inside)
http://youtube.com/watch?v=gHZ9VIEU4Bo
You folks think its my starter? My electronics are all functioning, but my car barely kicks over.
sounds very much like there's a bad spot in the starter ..that little hiccup just b4 the start. yes, I'd say time for a new starter. also, if you can, check your voltage while cranking...should stay above 10 volts. if below that check the battery & connections.
Try replacing the starter, when you have the starter out spin the engine by a wrench on the crank pulley and see if there is any chips or missing teeth on the flywheel.
It sounds more like a bad flywheel, but it can also very well by a bad starter, even though you might not hear gears grinding, its also worth a shot looking at.
Have you ever started your car twice? like start the car then grind the starter?
