where can I get an UDP
Old Aug 11, 2001 | 11:53 PM
CruzinMax's Avatar
Hey guys. Just a quick question about where I can get an Under Drive Pulley for a VE. All I see are for VG Max's. Everything is VG this and VG that. I'm getting a little ticked off. I don't care if I can find one in a Group deal or not. I just really want one. Thanks
Old Aug 12, 2001 | 12:02 AM
93 SE's Avatar
i got mine at www.aspracing.com $119 s+h also check rpmoutlet.com they have it for $99 but last i checked there under construction and i couldnt order,though you can still see page
Old Aug 12, 2001 | 12:45 AM
Jon91SE's Avatar
Pusssseeeehhhh
summitracing.......
Old Aug 12, 2001 | 08:24 AM
djslinkyz's Avatar
because VG's are better.
Old Aug 12, 2001 | 09:07 AM
DA-MAX's Avatar
Eat, sleep, and sh*t 2JZ
Hehehehe......
TRUE, TRUE....
Old Aug 12, 2001 | 10:42 PM
CruzinMax's Avatar
PFFTTTTTTT!!!
Old Aug 13, 2001 | 09:42 AM
Mizeree_X's Avatar
Getting back to his roots
One Question
I have heard that the ASP UD pulley is not a perfect fit on the VE -- you have to shave it down to get it onto the shaft. I also heard that the belt recommendations they give are incorrect. Can someone confirm / deny this? I am thinking about getting one but do not want a big hassle on my hands. Thanks.
Old Aug 13, 2001 | 10:16 AM
93 SE's Avatar
yeah its tight...you dont need to shave it but gently hammer it in,only the powersteering belt size they gave was a little small...the last 2 numbers on gates belt should be 75 or 78 ...for powersteering
Old Aug 13, 2001 | 11:24 AM
maxmizd27's Avatar
Re: One Question
Bolderdash! I have the ASP pulley. My dealership put it on because my crankshaft oil seal needed to be replaced anyway. They said it went on with no modifications and the belts are perfect. Numbers given are for Gates belts. Motor spins like a top now!
Old Aug 13, 2001 | 11:27 AM
Mizeree_X's Avatar
Sweet!
Thanks. I think I know what my next mod is now!
Old Aug 13, 2001 | 01:34 PM
CruzinMax's Avatar
which is better?
I see that there are a couple of companies that make the pulleys but now I wonder which one makes the biggest difference or are the results close to the same? Which belt numbers exactly? And how come the pulley from Unothodox is so much? When I get one is it a set of pullies or is it just one. How much work is involved in installation. I have put a CAI, Y-pipe, and RT cat on but nothing technical at all. Thanks again.
Old Aug 13, 2001 | 02:05 PM
93 SE's Avatar
why ve pullies r cheaper than vg i dont know but im happy about it,unorthodox only makes it for vg 3rd gen asp makes it for ve,as i know....do you have a ve or vg,its one pulley and for ve the belts i got were
a/c K040460, Alt. K050323, p/s. K0403778....as for installation if you have an air gun and mechanically inclined its simple...just as if your changing belts but while your doin that your also changin pulley...just jack up car pull passenger wheel and its all right there in sight
Old Aug 13, 2001 | 09:54 PM
CruzinMax's Avatar
Thanks for the help. I know what I'm goin to be ordering soon.
Old Aug 13, 2001 | 10:46 PM
ghostmax's Avatar
Hey I just ordered mine from Courtesy and was doing some searches and came up with the following quote from Dave B:
"Something to consider here. You've got a 3rd gen. The 3rd gens crank pulley is clearly defined as a "damper" in the Chiltons and Nissan manual, therefore I recommend staying away from the pulley.
I use to think the crank pulley on the VQ was a damper because I misread my Chiltons manual and didn't notice I was reading info about the VE/VG motors. The VQ is completely balanced and sports some very fancy race-breed internals (ie balanced). Believe me, I've researched this a lot and have asked many folks about this pulley because I had always been hesitant about adding a UDP."
Does anyone know anything about this? I don't want to install this thing and screw up my engine. BTW, how much would a shop charge to install this? Don't exactly have air tools yet. Thanks!
Old Aug 14, 2001 | 01:18 PM
93 SE's Avatar
yeah i read and heard that ,about it balancing engine,but other people have gotten it and had no problems....i was willing to take that chance for more hspwer
Dave B
May 29, 2001 11:07 AM
y2kse
Feb 25, 2001 08:47 PM
Andrew91SE
Nov 26, 2000 03:05 AM
ohboiya
Oct 9, 2000 12:23 PM
