Aftermarket Fogs
Originally posted by melanthius
My dad wants to hook me up with aftermarket fogs for the Max. I have the GXE (hence no fog lamps).
Which ones fit? Which ones are bright and look cool?
Any help would be appreciated.
PIAA 510 should fit the round whole on the Max.
I've seen them priced around $200 bucks for the whole
kit.
Here is one place for example
http://www.autoaccessorieszone.com/s...escription=510
Punch..
Are the 510's extremely bright? I've seen them in showrooms and they dont seem bright at all. Do you have pics? Thanks!
GC
GC
Originally posted by Punch84
I have a GXE and added PIAA 510's. I got the ion crystal ones and they are bad a$$. The projection on them is amazing. It's a tight fit so I'm still trying to find the best angle.
Cisco,
The ones I have are pretty damn bright. They shine as far if not further than our highbeams. Sorry, I dont have a digicam. If your looking for some try ebay. Thats where I got mine. I think they were $165 shipped.
Originally posted by 2Maxed-out4u
So if you by that Pia kit, it includes everything your maxima needs to have the fog lights to function.
I thought you had to change the light switch inside the car, or am I wrong?
piaa's are nice
if you want to put the fogs in the two holes where the stock fogs should be, then you should get the piaa 1100
they are the whitest and brightest it is so bright during the night you wont believe it, but if you are putting the fogs in the middle near the liscense plate, then i would reccomend the piaa 1900 or 1700, i am currently using the 1700, the color is similar to hid's
Whoa, thanks!
Thanks for your help you guys...
I'm talking about putting fogs in the little round holes in my bumper, not in the front valence.
I currently have PIAA Super Plasma H4 bulbs for the headlights, so which ones would match that color roughly?
What color is the ion crystal 510's? (currently considering those)
Can't we just buy the light control stalk (signalling stalk) from the SE or GLE for the GXE and then wire the Piaa's directly into the factory wiring? Then you won't have to drill through the firewall, and everything will look stock from the inside.
The Ion Crystal's are yellow. A lot of suvs have them on their brush guards.
melanthius: if you want to put the fog lights in the holes that are already there, then you should buy the piaa 1100's
i think they match any kind of headlight, because they are so damn bright
they are white not a bit of yellow or blue
they are the brightest fogs i ve seen, i would have gotten those if they fit in the middle, but i settled with the nice blueish color of the 1700's
cisco: here is a pic, they are actually brighter, because i took this pic in light, at night they look the same as hid's, because my tutor's 3.2 tl has the same fog light and i ve seen his car at night, it looks the same as his headlights
a couple of questions:
Awesome pic, thanks
melanthius
melanthius:
none of the fogs in my pic are the 1100's
my fogs are the 1700's that cisco asked for a pic of and the fogs in the wholes are the factory ones
the shape of the piaa 1100 fog light is round so it would fit in the two whole fine
when you buy the piaa fogs, they come with the bulbs already
Re: melanthius
melanthius:
melanthius:
i ve seen the 1100's and i assume they will fit
so before you buy it you should ask if it will fit
but if you want it to look nice, 1100's would be the choice
with it. 510's are the closest match to stock.
Re: Piaa's 959 or 910
Originally posted by Maxx-s-ter
will fill in the opening very nice. Check out my Homepage
Your homepage doesn't appear to have any pictures on it, FYI. Maybe I'm wrong, but the link to your homepage takes me to a page with no pix.
I also need good fogs...
Which PIAA are the best for real fog? Around the mountain side of Maryland (where I live) the morning fog is really bad so I need fog lights more for fog then style. Seems like the 959's have a wider angle (better?) but the 510 I.C.'s may have advantages I'm overlooking. From what I've heard the stock fog lights are an easy install but almost worthless (even though they use the same bulb as the PIAA).
If we can agree on a type maybe we can get a group buy!
Rude
Rude
OEM (stock) fog lights...
Are the OEM (stock) fog lights about the same as the aftermarket? I'm sure you would agree the most aftermarket items are a vast improvement over stock. I'd like to get stock since they're easier (and as low as $130 complete) but I've read many posts about the stock fog lights not helping much. I guess I need to see a side by side to see if the aftermarket fogs are worth it...or maybe I can even get away with H-3 4" round Blazers (they're under $25 at the hardware store).
Thanks for the suggestion...
Rude
Rude
Rude,
Aftermarket fogs may require a bit more due to routing the wires and all, but in the end it is worth it. I am running PIAA 510's, and they shine as far as my high-beams, but wider. I thought about getting OEM and replacing the bulbs with a yellow ones, but that would only change the color, not the projection. Good luck with your decision.
How did you install the PIAA 510's? When I looked at the maxima attachment it was two 3/8" holes spaced 2.25" apart but the 510's are a single 10mm center bolt, right? Did you make an adapter or drill?
OEM looks that best..
I think that the OEM's look the best.. i seen alot of other foggs on the 5th.. but the stock ones looks the best to me.... i want to get them sicne i have a GXE.. There was someone that posted up a form like a month ago about the the OEM Fogg light kit for like $127.00 but i can't find that post ne more.. so if ne of u guy's know wut i'm talk'n about.. can u post up the link to the compay that has them for $127... thanks..
Re: OEM looks that best..
http://www.nissanwholesaleparts.com/
You have to talk to a tech and ask for the best price...
I drilled a 10mm hole where there is a "step" in the housing. I have like a 1.5 inch bracket with one end screwed to the bumper and the other to the light.
if it is, i'd prefer to use the stock switch on my turn signal than aftermarket switch.
trsandrew
Apr 8, 2016 06:45 PM
trsandrew
Oct 25, 2015 02:47 PM
Calabar
Oct 5, 2015 09:57 PM
