Center Console, What's holdin' the rear end down?
Old Sep 5, 2001 | 07:57 AM
jmax
Okay, I know there are several of you who have taken out the center console in the 4th gen. What's holding down the rear end? How do I get it out? Thanks in advance.
Jmax and Skip
Old Sep 5, 2001 | 10:34 AM
Toolrocks's Avatar
Assuming you mean the section that has the arm rest, the way to remove it is to 'snap' out you plastic piece surrounding the trans shifter. There are two screws that should be very visible. Then you go to the back of the armrest's console on the bottom sides (you may want to slide your seats all the way forward to access the screws better) and unfasten these screws. Unsnap the parking brake boot and lift the console up from the rear and slide it towards the front of the car. It should come off easy. Good luck.
Old Sep 5, 2001 | 09:08 PM
jmax
I've already got the thing completely apart aside from the two rear screws. They seemed to be "invisible" when I looked a day or two ago. I didn't have time to slide the seats forward but figured it would be necessary. Thanks
Old Sep 8, 2001 | 07:35 PM
SWEETSOUND2001's Avatar
Once you slide the seats forward you will see the screws. Make sure you put some kind of soft tape on the front edge of the console where it meets the dash. This helps out with squeaks/rattles.
Old Sep 8, 2001 | 10:54 PM
jmax
Thanks! Maybe I'll have a minute tomorrow morning.
vingodine
45
May 21, 2016 12:46 PM
AcuraLegend
Sep 22, 2015 04:22 PM
JoshG
21
Sep 4, 2015 09:04 PM
wingsfan24
Aug 15, 2015 07:35 PM
