Weird noise when I turn the AC on
Hi:
When I turn the AC on I can here a grinding noise like a "rrrrrrr" coming from the area where the belts are. When I turn the AC off the noise goes away.
What could this be?
Thanks!
What could this be?
Thanks!
I would assume it is either the air compressor or the air compressor clutch. Your compressor isn't engaged (running) until you push the A/C button inside the car. Once you turn it on, the a/c clutch links the pulley that the belts are spinning and the compressor. This then causes the a/c compressor to spin internally. My car is doing the same thing. I am going to bend over and take it to the dealership. I am sure they will just want to replace the entire air compressor which will probably be expensive. You might be able to just replace the clutch though. I don't know enough about it to tackle it. Good luck.
My compressor made a similar noise for about 7 months. The A/C worked fine, the compressor was just noisy. It got a little worse so I replaced the compressor. 250 for a remanufactured compressor at Auto Zone and 150 for the install. This one is much quiter, however not as quite as I would like. I think a lot of Maximas have noisy compressors. Hope this helps.
Re: Thanks!!
Originally posted by ionicmax
So I can probably keep on driving my car without turning the AC on?
pears
Sep 18, 2015 05:25 AM
lrb6805
Sep 17, 2015 04:49 PM
