Need trunk enclosure help!
Old Sep 30, 2001 | 01:24 PM
SMX's Avatar
SMX
Ok…I need help. I want to install 2 –12 inch Pioneer free air speakers. I would like to place it on a front board that will be in the trunk against the back seat, and I want to enclose the area with another board to kind of like enclose the space. I’ll put a piece of clear Plexiglas so you can see the speakers. Does anyone have a temple or have and ideas for making a temple for the trunk? The two side of the trunk is going to be hard, also how do you think it will sound? Any help would be will appreciated!!
Old Sep 30, 2001 | 10:30 PM
jmax
Well there is just one problem. The install you describe, "I want to enclose the area with another board to kind of like enclose the space," is a box install. Not free air. So use subs designs to go in a box. I know you probably chose free air because they are the cheapest. Some free air subs will work in an enclosure, or they all will, but maybe not work well. What year is your maxima? That will tell us which 'template' you need. Then we will work on the sound quality you want. Do you want lots of boom, or clean, accurate attack and smooth roll off. Or a trade-off.
Old Oct 1, 2001 | 05:25 AM
SMX's Avatar
SMX
Clean and accurate is what I'm looking for, dont need all that boom, my max is a 96. What the next step? Thanks
Old Oct 1, 2001 | 11:47 AM
ispeed's Avatar
don't know for sure what the doctrine on free air subs are now, but back in the day (which I'd say still holds true) you need to completely seal the trunk from the rest of the car in order to get a good sound. with free air, you are using the trunk as an enclosure, therefore the baffle board and the entire trunk needs to be sealed from the cabin. this is done so the wave produced by the cone moving forward is not cancelled by the cones rear movement. without having it totally sealed it will sound like you have the sub playing with no box at all.
Old Oct 1, 2001 | 12:49 PM
SMX's Avatar
SMX
Ok so in other words I'll be better off placing the speakers in a box?
Old Oct 1, 2001 | 02:50 PM
ispeed's Avatar
my opinion ... yes.
does it count for anything ... well my 2 cents don't buy much
Old Oct 1, 2001 | 09:04 PM
jmax
I agree. My 2 cents chipped in still doesn't pay the tax on a large cup of coffee.
Old Oct 2, 2001 | 05:18 PM
SMX's Avatar
SMX
Thanks For the input. I'll go with the box
Old Oct 3, 2001 | 10:45 AM
theMax's Avatar
For tight accurate base I'd go with a sealed box. They are typically smaller than a ported. If it is one box make sure the chambers are sealed.
Old Oct 5, 2001 | 05:39 AM
psyclotran's Avatar
new idea?
I have always wonder if anyone has tried this...
Since the trunk is at least 18 cu ft, why not use the trunk as the enclosure. Let me expand. Why can't you put a few port holes into the board that holds the rear speakers? Can this board be removed from the car? This way, you can package the speakers so that it will look hidden and not have to worry about tight enclosures and all.
Isn't port enclosures more efficient anyways?
What do you guys think?
Old Oct 5, 2001 | 12:51 PM
theMax's Avatar
Re: new idea?
Ported enclosures are more efficient but not as accurate. They are louder but not as clear as sealed. Ported are better for rap/dance/bass not for rock/classical.
18 cuft is to large. Check the specs on the speakers. Most of the 12" need about 2 cuft. you can deviate about +/- 20% but more or less than that will degrade sound quality. You can do it if you seal the trunk from the rest of the car but a box is better.
Old Oct 5, 2001 | 12:56 PM
Matt93SE's Avatar
STFU n00b!
or you could just buy half a dozen 12s that use 3cu ft each, and seal and brace the hell out of the trunk like me... then throw a few firing into your rear seat, and some in your rear deck and power the **** out of them.
Kaboom.
Old Oct 5, 2001 | 06:10 PM
psyclotran's Avatar
Re: Re: new idea?
12s are too large. I rather have 10s or 8s. The bass is tighter and faster. Now I need to figure out how to use 18 cu ft of volume.
Old Oct 5, 2001 | 09:59 PM
jmax
Re: new idea?
It sounds like you are trying to turn your trunk into a bandpass box, with the ports firing into the cabin. This is possible, but a sealed and carefully constructed box is needed. Not to mention a carefully sealed trunk. There are many holes in your trunk. Like the one on each side in the fenders that allows the trunk to vent so the lid may close.
Old Oct 6, 2001 | 07:45 AM
theMax's Avatar
Re: Re: Re: new idea?
Do you have acess to wood tools? Circular or table saw and power drill? If so I could help you design a sealed or ported enclosure.
You could cut a hole in the back deck and lay the speakers right there. I've done it with 6x9's. You need somthing to cut through the sheet metal.
REDinLV
Aug 15, 2024 12:30 AM
mrgooch
Sep 21, 2015 08:43 PM
lux97Max
Sep 14, 2015 07:07 PM
Mikes14Max
Advance Paint and Body Work
Sep 14, 2015 05:28 PM
rbaker100
Sep 6, 2015 02:46 PM
