RSB off...car handles better?
Lately I've been noticing a clunking noise from the back of the car when I would corner at any kind of decent speed, so today when I was getting my oil changed I asked the mechanic if I could take a look at the RSB and adjust it if necessary. What I found was two of the bushings on the brackets holding were split in 3 places and basically falling apart. I took the thing off since I was already tired of the damn thing hitting the ground if I had a carload of people and this didn't reinforce my opinion of it any. I never really noticed a difference in the first place, but on my way home I took my usual route, and decided to push it a little and see if I could tell it was gone. Well, I could, but I was able to corner better than I was with it on, and got the opposite result that I expected. I took it for a spin on some of the curvier roads around and confirmed it. I had the Addco RSB, so I'm wondering if maybe that's what made the difference. Everyone always talks about how much better the car handles with it on, but maybe it's the Stillen one that makes a difference. Any thoughts?
Check this thread out: http://forums.maxima.org/showthread.php?threadid=71210
Another member had clunking noises as well. But we found the problem in time. I would NEVER take off my RSB. I love it too much.
Originally posted by MaDxKiLLa
u mustve installed ur RSB wrong......
Originally posted by nc00max
No, it's pretty much a no-brainer, and the brackets only fit in one spot and the bar can only go on one way. But the Addco RSB is from the 4G Max's and as a result I don't think it'll do much for the 5G's.
My car was lowered before installing the rsb and it made a nighte & day difference after the RSB!!! The body roll was almost completely elimated.
BTW.. If your rear beam is hitting the floor everytime your car is packed, you might wanna get that checked out... I bottom out occasionally, especially with added extra weight but the only time I hit the floor is when I run over deep potholes or steep curves.
yes
it is a very good mod, i haven't had any problems with the RSB, but i do notice a little clunking noise with the stillen one. it doesn't clunk every time, just sometimes when i make a right or go over a bump. do any of you have a problem with the stillen rsb, and how can i adjust it?
Re: Clunk
Originally posted by maddmaxx
Ya, I get the clunk also with my Stillen bar.Only seems to happen on the right side,with a load,or cornering and hitting a bump or pothole.
depends on the driver too. Some drivers LIKE body roll, it sometimes gives the impression that it handles better or is more predictable.
handling is almost completely driver biased.
I tend to love off-throttle over-steer... others don't.
He probably just got more confidence, took the corner faster, braked better, accelerated earlier.
Re: yes
REDinLV
Aug 15, 2024 12:30 AM
thatcollegestudent
18
Oct 5, 2015 02:29 PM
I have the stillen RSB and the difference with and without it was night and day....
