Bleeding ABS brakes/installing Actuator
Old Sep 13, 2007 | 05:26 PM
92gxe/cg2's Avatar
92 ABS Modulator Not Pumping to Rear
So my 92 GXE's abs modulator isnt pumping fluid to the rear, instead its slowly leaking from the modulator, so basically that thing is on its way out and i need a replacement used one. i got quoted 100 or less for a used one and 2+ hours of labor plus brake bleeding by midas and i really have no money right now but this needs to get fixed as i only have front brakes and they feel squishy... sorta. Well i was wondering if i could simply cut the lines from the master cylender where they go into the modulator and cut the lines that come out (there like 3 inches apart) and connect them with adapters or w/e they sell. So would this work? I know that one post was talkin about how after 5 mins the brakes locked up or had to much pressure, will this be the case of wat? I just want to simply bypass the abs modulator, so id have regular brakes. How hard would this be and if its not possible where are some places to look for modulators and how hard is an install on one of them? (i know JY would have em but how do i know they'll work.... Thanks in advance guys i really need help.
Old Sep 16, 2007 | 06:08 AM
internetautomar's Avatar
mod or sell?
it's not on it's way out.
it IS out.
do not drive the car until you have it fixed.
if one section has already failed how far behind can the second section be???
Old Sep 16, 2007 | 06:15 PM
92gxe/cg2's Avatar
well i got a used one at a JY for 65 so il install it monday or tuesday...
hopefully itl all go well, anyone know which tires to bleed first, i think its rear passenger.... im not sure tho
Old Sep 16, 2007 | 08:10 PM
92gxe/cg2's Avatar
So within the next few days or so i will be removing and installing a used ABS actuator from the JY i got for 67 bucks. After i install it im naturally going to need to bleed the brakes. I know u start with the wheel that has the longest line to it and move closer... but wats the wheel order for a 92 gxe with abs? also do i disconnect the harnesses from the actuator when im bleeding or put the car in ACC mode (someone told me thats how to do it but i dont believe that)? so if u guys could help me out, im a noob with car stuff but i cant afford to have a shop put this in... and i got it out of the JY car fine so im sure i can get it in mine right? i hope so...
Old Sep 16, 2007 | 08:16 PM
Greeny's Avatar
¯\(°_o)/¯
I merged both your threads on this issue into one thread,no need for 2 subjects on the same thing on the same page..
Old Sep 17, 2007 | 10:40 AM
mod or sell?
rule of thumb is as you stated start with the wheel farthest from the master and work your way closer.
Old Oct 7, 2007 | 12:43 AM
92gxe/cg2's Avatar
So i read on Auto Zones repair guide that during the bleeding process if u have abs u should bleed the ABS actuator. Well my question is how do you bleed said actuator?
bbsitum
Sep 6, 2019 07:31 PM
leatherneck
Sep 30, 2015 09:16 PM
imported_Nismo_max
Sep 20, 2015 08:19 AM
ajahearn
Sep 19, 2015 03:03 PM
maximusrising
Sep 2, 2015 09:55 AM
