Capacitor's Place...
Old Sep 16, 2007 | 09:30 PM
shyheim07's Avatar
So i'm gonna run 3 amps...1700 watts rms total (estimate)
Don't know much about caps, but everyone says to install it as close to the amp as pissible, or before the amp...I'm using distribution block of course, but i dont want the cap to work for just one amp so...can I just put the cap (2.1 fared or more?) on the power wire before it hits the distrubution block?
Battery----Cap----Block----3 Amps?
Old Sep 16, 2007 | 09:45 PM
kpr10is's Avatar
Step 1. Throw the cap off a cliff.
Step 2. Get a nice battery up front and do the big three.
Step 3. Enjoy
Old Sep 16, 2007 | 10:05 PM
shyheim07's Avatar
did the big three, got yelltop, 220 amp alt..
no cap needed? still dims
Old Sep 16, 2007 | 11:27 PM
AscendantMax's Avatar
220 amp alt and it STILL dims? there's gotta be a weak ground somewhere if you still have dimming issues with your beefed up eletrical.
Old Sep 17, 2007 | 12:06 AM
maximal's Avatar
if you really want to use a cap, put it on the sub amp. your other amps won't really need it.
otoh, i just saw your other thread on preout voltage...
i have a feeling that's your problem right there. you have low preout voltage and in turn are maxing out your gains to try to get loud. this is straining your electrical system.
my hu puts out 5v and my gains are set at maybe 15-20%. i don't go past 14 on my volume ****...
Old Sep 17, 2007 | 04:13 AM
shyheim07's Avatar
well, i dont max out my gains, thats just not smart. I turn it up to 2, since the volts are two. its about 20%. i dunno. I have 4 awg runnng, maybe i will sound better when i put in 0
Old Sep 17, 2007 | 07:33 AM
arkainshadow's Avatar
cap=crap. something else is wrong. 220 amp and your diming? like AscendantMax said. probably a bad ground... check your battery terminals for currioson. make sure your ground is secure. fyi doesnt matter were you place the cap, it will work the same. in theory you could put it under the hood and will have the same exact affect, more strain on your system then benifits.
Old Sep 17, 2007 | 08:17 AM
spark plugs.'s Avatar
Hi, I drive a Maxima.
cap's place? in the garbage
Old Sep 17, 2007 | 09:42 AM
BLK2BLU's Avatar
Guys, you don't have to throw the cap away, I use my friend's old one as a paper weight
Old Sep 17, 2007 | 05:34 PM
Batxel's Avatar
blah
Depends on how much the alt is putting out vs how much your drawing from it. My 220 amp alt doesn't do much of anything at idle so I do get dimming there but 1k rpm+ I don't get any diming and I have no where near 1700 watts rms. Mine is an iraggi which states 100A at idle when it probably does only 35A at idle. I don't think he knows what the idle is on maxima with a 5 speed.
Old Sep 17, 2007 | 05:47 PM
maxboy325's Avatar
Battery----Cap----Block----3 Amps?[/QUOTE]
yes you can but shouldnt need it i run 2 amps on an old stock type batt and dont dim
do you have a UDP?
Old Sep 17, 2007 | 05:49 PM
mendon99's Avatar
tastey wheat
lol was gonna say the same thing!
Old Sep 17, 2007 | 06:45 PM
we need a cap sticky. weres that write up i did on them.
Old Sep 17, 2007 | 07:11 PM
Pearl96Max's Avatar
I tend to get a bit irritable
Cap .. trash can.
Something seems to be the issue with your electrical, or your amps are just THAT inefficient.
Old Sep 17, 2007 | 07:12 PM
Pearl96Max's Avatar
Invest in post-its, they dont fly away.
Old Sep 18, 2007 | 02:04 AM
maximal's Avatar
i figured you'd already upgraded to 0 awg. that could be your problem right there.
Old Sep 18, 2007 | 04:39 AM
djfrestyl's Avatar
Suspension Yoda
This thread reeks of a poorly designed system, on the OP's part.
Old Sep 21, 2007 | 06:35 AM
shyheim07's Avatar
how so? The 4 AWG was running only the 4 channel. Subs were not even in.
Yeserday my 0 awg kit came in. Fused ditribuition black and 0 to 4 awg. Everything is solid.
Don't even have to use the base boost so its not drawing anything extra. At idle, it does dimm, but its not like the engine putts or anyhting, just a quick drop then it right back up. On the highway, I got up to 14.3 volts and it got loud as hell, but it does not dimm above 1000 rpm, so the caps place is the trash..good lookin' out
Old Sep 21, 2007 | 09:17 AM
chinaonnitrous1's Avatar
Do Alumapro Caps belong in the Garbage too?
I've been out of the loop for a while. I have the Flat 25farad capacitor thingy.
Old Sep 29, 2007 | 08:58 AM
djfrestyl's Avatar
Suspension Yoda
All caps belong in the trash.
edit: except those that are already inside your amp
Old Oct 1, 2007 | 04:21 PM
LoMaximA96's Avatar
they make nice paperweights
Old Nov 5, 2007 | 07:19 PM
pikers's Avatar
...Dumpster.
Actually no, might get in trouble for improper disposal.
EDIT: I read the whole thread after posting, and I have to say that your local landfill seems to be the consensus.
DaveGrun
Jul 23, 2002 06:34 AM
D1NOnly34
Jun 21, 2002 02:38 AM
Nick97SE
Jun 3, 2002 09:07 PM
MaximaGold
May 22, 2002 09:36 PM
MaxedOut2g
Nov 19, 2001 08:07 PM
