Idle dipping to 500rpm
Now that I've replaced the fuel rail adapter because of that incident 3 weeks ago where the hose connecting to the fuel rail popped off from too much pressure I've noticed that when I start the car in the morning the rpms would settle around 650~700rpm and then after a short while it would drop down to 500rpm. The car would be noticeably shaking when this happens and after a minute of this the rpm would climb back up. I've not noticed this happening after the car has fully warmed up. Would this have anything to do with the coils?
I've got:
- Aeromotive FPR
- BEGI fmu
- Walbro 255lph pump
I've got:
- Aeromotive FPR
- BEGI fmu
I'm not trying to hi-jack your thread blackcat, just trying to maybe help solve both our problems if it's the MAF...
i dont check my car for codes cause no one near by has something to check them with. When you unplug your maf it should run good up until 3500 where it kicks back. When mine was bad it would just sputter on starts and would hesitate when you give it gas from an idle.
Autozone will run a free scan for you.. just ask someone behind the desk.
I'm having this problem as well, my car idles around 500-550(5spd). Also, sometimes, on acceleration, the car has a very slight surge, and every now and then when I make a full-throttle pull, at around 5-6k or so the engine will briefly cut out. Would the MAF going bad make it do this?
that might be it, go and get some CRC MAF cleaner at checker or advanced autoparts or autozone. any place like that its like 5 bucks, then spray it n your hot wires in your maf a few times and it should clean them off. thats the cheap way to fix the problem, it might start to stumble again in 10xxx miles or so but then just do it again it it will fix it, another way to test if your maf is Effed up is take a screw driver or tap on the center of your maf with your knuckle and listen closely to see if your engine stumbles
No worries, MadMax!
No Check Engine light on yet but I'll have to get some maf cleaner, run the codes and tap the maf housing.
Just found this thread on the Throttle Position Sensor:
http://forums.maxima.org/showthread....ht=maf+failure
and
http://vbxmaxima.8m.com/tps.html
This must be the problem.
and
My car had that problem it dipped to like 200-300rpm I clean the TB and Seafoamed it and it stopped doing that, but my car idles at 500rpm when im at a stop light with no vibration and its not throwing codes either the even when it was doing its deadly dip
Canadian pricing is $112.00 for the tps and $550.00 for a maf.
DaveB is selling the maf for $385US.
Blackcat if you were closer you could borrow my multimeter. But it is also a very handy thing to have around id definately recommend you getting one. If youd like i can get you a price on a OEM TPS, might be able to save you a bit.
. I sprayed it out, put on a new fuel filter, and checked my plugs. The plugs looked great, but I am probably going to change them just because they are the NGK coppers and they have about 20k or so on them...The car still runs the same, even after the filter and MAF cleaning. I also hooked the scanner up, and the only code I have is P1336 - MFR Cntrlld Ign or Misfire. I just changed the CKPS(REF) and the CPS last week - the car wouldn't even start with those messed up. Now I just have this missing problem but it is throwing the other crank position sensor code - I just don't know how it still runs with the crank sensor problem.
I am going to change my oil/filter and test my coil packs tomorrow, hopefully this will reveal something of use to someone...
Thanks Scott, but I just picked up a cheapie one from Canadian Tire yesterday for $20.00. I also found a tutorial on youtube on how to use it. I ordered a tps as well from Morrey Nissan.
Darn thing cost me $110Cdn roughly.
I installed the tps last night. Its just held on by two screws. This morning when I cranked the engine the idle did not lope anymore. Idle was a steady 650rpm and never dipped to 500rpm when the engine was cold.
When the engine was fully warmed up the loping would disappear but I was starting to experience flat spots whenever I stepped on the throttle before the tps change.
The Haynes manual has a description of the symptoms I was experiencing for the tps.
Now the problem is gone! Throttle response is restored to what it should be. So even though my maf took a little tumble that wasn't the cause of the problems.
I now believe that once a Max turns 10 years old a tps change would be necessary.
REDinLV
Aug 15, 2024 12:30 AM
Unclejunebug
Apr 2, 2016 05:42 AM
