weird clacking noise coming from the front driver's side
Old Sep 20, 2007 | 12:46 PM
vqmaxman's Avatar
I been noticing this weird clacking noise coming from the front left side. The noise only is there when I am driving around 5 mph. The noise more like a clack clack clack then as I go faster it would go away. I would also be on the hill parked upwards then I would put the car in D and drive off the clacking is there untill I pick up more speed then it gets quiet. I am thinking it's my drive shafts or cv shafts. anyone. Thanks.
Old Sep 20, 2007 | 02:16 PM
vqmaxman's Avatar
anyone with any clue
Old Sep 20, 2007 | 06:01 PM
Punk In Drublic's Avatar
I have the exact same rattle in my 96 GLE, it's pissing me off. let me know if you figure out what it is.
I look around and found this... doubtful that this is the cause but it's always possible.
http://maxima.theowensfamily.com/tsb/NTB98-023.pdf
Old Sep 20, 2007 | 06:18 PM
67whitegoat's Avatar
Clack clack clack it typically CV joint. Go to a parking lot, turn the wheel to the right and accelerate. If you get a clack clack clack.....
Old Sep 20, 2007 | 08:59 PM
vqmaxman's Avatar
Originally Posted by 67whitegoat
Clack clack clack it typically CV joint. Go to a parking lot, turn the wheel to he right and accelerate. If you get a clack clack clack.....
I've also heard if you can just turn the steering wheel in either direction you could also hear the clicking noise that means it's the cv joints vs the clacking I am defently sure that it's the cv shaft but it's to hard to know what it clearly is.
Old Sep 20, 2007 | 09:12 PM
maximak1d's Avatar
i have a similar problem maybe even the same thing (hard to tell without hearing ur sound)
mines more of a ticking mixed with a shhhhhhhhhh
and it starts wen i start my car and accelerate around 5mph-20ish but after a while it stops
and its not too loud,
i have a 06 max with 9k miles so i unno wut it could be
Old Sep 20, 2007 | 10:24 PM
20" Max's Avatar
I have the same ticking problem, I don't have a clue what it may be. I saw that my outer cv boot has a slight tear in it but not sure if that is causing the prob.
Old Sep 20, 2007 | 10:38 PM
helps
are your lugnuts loose?
Old Sep 21, 2007 | 10:19 AM
vqmaxman's Avatar
From what I heard is that if you have a slight tear in the boots you should get it replaced immediatly. If not the axle can go bad cause all of the grease can leak out of there. and your axle will be bone dry.
Old Sep 21, 2007 | 10:20 AM
vqmaxman's Avatar
If my lug nut's were loose I believe I would of have had the car fall out while I am driving at high speeds or at turns or the threads stripping.
Old Sep 21, 2007 | 11:16 PM
vqmaxman's Avatar
I have 2 clips that I rec I hope this helps out.
I have the first one here and it's outside of the car near the front wheel.
I have the second one that's inside of the car. (Crank you vol up on this one)
If you guys can't tell what it is then i will try to do it on the cam corder.
Old Sep 22, 2007 | 07:15 AM
Snypa's Avatar
def cv joints,also try turning your steering far right or far left and reverse slowly.
Old Sep 22, 2007 | 08:03 AM
JtzMax's Avatar
Whatchyou say?
could also be a tie rod end or ball joint too
did you check the lugs .... ??? They may not fall off ya know. I did my brakes a while back and forgot to tighten them up ... snugged em before I dropped the car back down, drove out to a mates house (45 min's away) and on the way home I remembered that I didn't tighten them all the way. Made a slight clicking noise and that is what made me remember.
Also ... to check CV joints, you need to be moving, not just crank the wheel. If it's CVs, you may also feel it "jerk" at take off or let off of the throtle.
Old Sep 22, 2007 | 10:15 PM
vqmaxman's Avatar
I always make sure that the lugnut's are tight and I always work my way around the vehicle so I have tighten them all out. I checked out the ball joints and the whole suspension I believe everything is rusting out but not to much. I also feel a slight viberation on the tie rods I am not sure if your supposed to feel them or not when I have the car on the jack.
Hondarydr
Dec 30, 2024 06:15 PM
kingw323
20
Oct 21, 2015 08:36 AM
erniel
Aug 8, 2015 09:32 AM
BassAddictJ
Aug 4, 2015 11:38 AM
Jcof88
Aug 3, 2015 10:43 PM
