so tommorrow i lower my car.
im not quite sure about the inches, the guy who is doing it for me told me to think about how many inches i want lower. im debating about 2.75 in the front and 2.5 in the back but im worried about when it settles if its going to start rubbing up against anything. and oh yea... im cutting the springs and have a pair of tokico shocks. so what do you guys think should be a good amount of inches to lower it to cover up the wheel/ fender gap.
oh and a little off topic, but in a week or two im also ordreing my exhaust.. its between a monza 2 1/4 inch pipping or megan 2 1/2 inch pipping.. brand doesnt matter, i just want to know whats best pipping diameter for us maximas.
Get a y-pipe and leave the stock cat back. If you must, get a Cattman B-pipe and a 5th gen rear muffler.
Just save up and get some quality springs. Cutting stock units is just a bad idea. People have done it and we've talked about it before, but in the end, a set of springs is just a better idea.
Hi-jacked his own thread.
Cutting your springs is a no-no.
-It WILL be a horrible ride,
-you will scrape on just about everything, when you look under you car theres alot of parts that hang quite low,
-stock springs are quite soft, but thats fine when they have full travel to work with
-when you buy lowering springs they have non-linear travel, so you get about 1-2 inches of a "softer feel" with the sping rate, but when you hit a big bump the springs become quite stiff as they compress more.
-a small side note. you will not have any stock spring to go back on if you ever want to sell your car.
its been said before but it really is worth the small extra amount of coin to get real lowering springs.
also. 2.75 is a very low drop, it will start to mess with your alignment, most likely you will need an alignment kit, I would never recommend for than 2.0 -2.2 inch drop unless you have coilovers.
i dont know if you guys do it over in the USA, but over here ive heard of some people doing spring compression. I think basically they throw your springs into an oven and compress them - that way at least you can specify spring height whilst keeping all the coils.
Personally i'd still buy a set of aftermarket springs, as the thickness of the coils on the stock springs is quite skinny (this I guess makes them soft). If you want more drop again, compress your aftermarket springs.
2.75 inches will be laughable, you'll literally be riding on your bump stops. I had to cut my bump stops at a 1.5 inch drop. Don't do it.
You want good handling and good looks? Get Eibachs. Cut the bump stops. Cutting your springs is ghey. Do it right.
Staggered for now, they just kind of fell into my lap so I am hoping I can come by a set of rears (maybe from dorifto folks) and throw some wideboys on there.
I was actually looking for some R33 wheels (wide, forged, nice offset, OEM+ look) but they are all in Cali and I couldn't pass on these guys.
Here's what my drop looked like. It's only a 3.5 cm drop (sorry for the lack of imperial measurements again guys!!)
This was a pic taken just after I put them in. Theyve settled a bit more since then.
I didnt want to go too low because of the monsoonal gutters in the tropics - i'd end up losing bits off my car
BEFORE:
AFTER:
heres the stock springs sitting in the box the King springs came in.. lol.. gives you an idea of the size of the drop..
Apologies on the size of the images...
BEFORE:
AFTER:
how heavy are the R33s?
whaaat? So if i got lowering springs it would cause the car to scrape bumps? I am talking about with the bottom, not the wheels(lol i may be thinking your nuts, hopefully u meant the bottom aswell...)
depends the drop you get, and the size of the bump, and how you go about going over the bump.
pears
Sep 18, 2015 05:25 AM
15th post
. I think that with ANY spring/strut combo, you're going to hit a bump, unless you're driving a hovercraft
------>I didn't even snap that this thread is getting old. 9-30-07.
