Sponsored by:
Sponsored by: CARiD
power loss w/3.5 swap
Old Nov 18, 2007 | 01:48 PM
Weimar Ben's Avatar
Helicopters! Money!!!
I have about 10k miles on my 3.5 swap now and lately my power's been sucking. I have cattman gen III headers and a SSIM. The low end feels ok, I get a huge dip around 3500 where I can barely get the RPMs to rise, then it feels ok, but not great from 4500 to redline
I just bought an OBD-II capture/scanner. I'm getting only 5deg of ignition timing at idle, but as soon as I blip the throttle it sticks around 40 deg at just about every RPM.
Could I have a broken dowel pin where the sprockets could have shifted?
My gas mileage has been sucking really bad, but that could be because of apocalyptic seattle traffic.
Old Nov 18, 2007 | 03:24 PM
Kevlo911's Avatar
Kevlo for President
How is the oil level?
Old Nov 18, 2007 | 03:46 PM
nismology's Avatar
Yea, sounds like the motor skipped time.
Old Nov 18, 2007 | 04:03 PM
Weimar Ben's Avatar
The oil level's fine.
The TPS looks to be giving me troubles. The TPS reading was at 0% at idle. If I adjusted the TPS, then the timing goes up to around 25deg. The problem is that no matter how I adjust the TPS, I can't get the full 100% range. It'll be 0-90% or 10-100%. I'm using the modded 3.5 TB.
Under WOT, the timing is at 15deg.
I also found that I was getting a O2 sensor code and that gnd wire for the O2 sensor in front was broken. So that probably explains the mpg.
Old Nov 18, 2007 | 04:04 PM
nismology's Avatar
Edit: Question had been answered.
Old Nov 18, 2007 | 04:05 PM
Weimar Ben's Avatar
so basically, if TPS % is at 0%, then ignition advance will only be at 5. Does this seem correct?
Old Nov 18, 2007 | 04:08 PM
nismology's Avatar
That sounds about right. Since the TB is slightly opened at idle to make up for the loss of the IACV the range of motion relative to stock will be limited. It's always best to calibrate the TPS to the WOT voltage/resistance specification when you've adjusted the throttle stop screw.
AaronL
Nov 15, 2020 11:52 AM
Socalstillen
Sep 20, 2015 11:46 PM
MaxRPM6
Sep 11, 2015 06:56 PM
I<3 A32's
Sep 10, 2015 11:07 AM
