wood dash instalation
any tips on installing a wood dash trim for a 00' or 01' maxima. any suggestion on where to buy a kit? i looked at exotic wooddash and wooddash .com
both seem reasonable. thanks
Take your time when you are installing it. It should be done on a warm day or indoors. The parts and surfaces should be gently warmed up with a hair dryer. Pre fit everything before you expose the adhesive - you only get ONE chance to get it right. The hardest part on the 2K is the piece above the shifter because it has multiple curves. You may want to bribe a friend to help out, a second set of hands can be useful to hold the dryer while you position the piece.
If you are weary about do this install, might want to think about a MOLDED kit. That way you dont have to worry about heat guns and sticky tape and only getting once chance, plus it looks better cause it looks more OEM, and not like a piece of wood STUCK on top of the old moldings
MaxLife17
Jun 27, 2019 01:37 PM
