Swoosh swoosh swoosh from wheel area: Axle, CV, or bearing?
Automatic, non-LSD vehicle that I am working on for a friend...
Passenger front wheel is making a "swoosh"ing noise. It is variable with vehicle speed, not engine RPM. Transmission shifts very smoothly.
The sound is the same whether traveling straight or turning, but definately varies with vehicle speed.
Am I looking at a CV, axle, or bearing problem?
Could very well be a wheel bearing problem. They seem to be more of a moaning/groaning type noise that varies with speed but is often heard at the 30-40mph range it seems where wind noise and engine rpm isnt a big factor.
When my wheel bearing went, it was pretty much what you described, like a swoosh swoosh noise i didnt notice it on the hwy but it was most noticeble at about 30mph. Put the car up on the hoist and got my freind to drive it and just listened with a stethoscope and sure enough my wheel bearing went bad.
My rear tires are "chopped" or unevenly worn. They make a swooshing noise from 20mph+. I doubt it is an axle or CV because usually those clunk when they go back, and if they are bad usually the CV is torn and axle grease is everywhere. If he has good tires, and the CV's arent busted, I would have to say wheel bearing.
Sound can be heard from the time the car moves- you don't have to be going fast. I am about to pull the wheel in the next hour.
No clunking- it is definately a "swoosh" sound.
Thanks for the help so far...
Is the sound constantly able to be heard- just increases with speed. Then at highway speeds you cant really hear it...I had the same noise. I'd bank on it being a wheel bearing....jack up the front and check to see if you have a lot of play in the bearing, if so you found the problem..
Well, for one, as the bearing gets more use it will build up more and more play...thus causing excessive/irregular tire wear. Believe me, (I went through a set of kuhmo ecstas in about 2 months).....
Second, it causes additional problems because the wheel bearing is pressed into wheel hub, the main assemlby of the wheel, and if you drive too long with a thrown bearing it will score the hub causing you not only to need a new bearing but additionally a new hub assembly.
And if you drive insanely too long with a thrown bearing and wheel hub your wheeel might jus fly off your car and kill you......
but seriously.
Ive been having a similar problem too.
Noise starts from about 30mph and increases, whether in gear or not.
Finally we got out the stethoscope and put that badgirl on the lift, and took it up to "highway speeds". (pretty nerve racking being on the lift, running through the gears
) Seems like the noise was originating from the passenger side of the tranny where the axle sets in.
I can't change that at home without a bearing press, can I?
I believe if you jack up the car and the wheel has play if you wiggle it on the top and bottom of the tire it's your wheel bearing. I just swapped mine out two weeks ago and now i got the same damn noise again
DAMMIT.
DAMMIT.
Are you running crazy spacers or wheels with crazy offset? If you only replaced one wheel bearing it might just be the other side...
If gone not fixed it is possible that the wheel comes off while you are driving it. Not something you want to experience.....Just get it fixed it is worth it for your safety.
So if I did not have any significant play in any direction, is it still the bearing, or is it the hub, like this other guy?
I did jack up both sides and check for any lateral play. Neither side had any, although I had no idea what I was actually checking for. I just figured that if I pushed, pulled, and twisted and something was loose, that would help my diagnosis.
BTW the bearing test is not conclusive, it is more of an affirmation--the bearing can still be bad without having any play in it.
In addition, checking with your hands isn't going to do much unless its pretty f'd up, in which case you'd likely be feeling it while driving.
Any update on this issue? This sounds like the problem I've had with my car. In addition, I've had to retighten the axle nut. That got rid of the noise, but doesn't explain why it came loose in the first place. (Happened twice in a year..)
The Wizard
24
Oct 1, 2015 08:47 PM
londonflu
40
Sep 25, 2015 09:11 AM
