smoke from engine
Old Dec 10, 2007 | 01:07 PM
Olezhka's Avatar
smoke from engine
I have smoke/steam coming out the back side of my engine when it's hot. Smells like engine oil.
I can't really tell where it's coming from. Could this be the valve cover gasket?
If not then what else can it be?
ANd here is a close up
Old Dec 10, 2007 | 01:22 PM
7jackmack's Avatar
Sounds like it. Area you have circled is the same spot that my valve cover is leaking.
Old Dec 10, 2007 | 01:24 PM
Olezhka's Avatar
LOL, I saw your post and it reminded me about my problem.
Old Dec 12, 2007 | 01:09 PM
mevjen's Avatar
The self-oil changing max
check your timing chain cover, valve cover, and oil pump, maximas seem to have problems with these areas leaking. If you have a leaking timing chain cover or oil pump, a shop fix will be expensive, so good luck. Get a flashlight and inspection mirror and check that area you circled by your firewall. If it is from the valve cover, it will be a pretty substantial smear if it is causing it to smoke.
Old Dec 12, 2007 | 01:11 PM
kzoosho's Avatar
If it was oil it would smell too. Check for a smell also.
Old Dec 12, 2007 | 01:32 PM
Olezhka's Avatar
Yeah, I mentioned before that it smells like engine oil.
Old Jan 4, 2008 | 05:48 PM
solow's Avatar
1 LOW MAX
mine smokes from the same place and i was looking and its the valve cover gasket good luck
Old Jan 5, 2008 | 10:41 AM
tarun900's Avatar
Yeah re-sealing those leaks costs a lot of $ at repair shops. I had to pay around 300$ on my old Altima to get everything around the engine resealed (it had been in a wreck about 4 months before apparently the original seal had worn down and oil was slowly leaking).
shilov
Feb 19, 2024 09:40 PM
Socalstillen
Sep 20, 2015 11:46 PM
seesole
Sep 14, 2015 12:38 PM
ballerchris510
Sep 11, 2015 05:29 PM
ballerchris510
Sep 10, 2015 09:35 PM
