Loose tire belt
Old Dec 14, 2007 | 10:16 AM
DJMaxGLE's Avatar
Loose tire belt
I have Cooper tires that were installed a couple years ago. One of the front tires has a loose belt, which causes my steering wheel to wobble a little bit. Is this fix-able at a mechanic, or do I have to get a whole new tire?
Old Dec 14, 2007 | 03:18 PM
Greeny's Avatar
¯\(°_o)/¯
you will most definitely need a new tire..
Old Dec 15, 2007 | 08:42 PM
Delvin's Avatar
Belts are internal and cannot be repaired. The only things that can be repaired are some punctures in the tread that are not too close to the sidewall. Start looking for a new one.
Old Dec 17, 2007 | 11:32 AM
d00df00d's Avatar
Old enuf to pick his own gears
Get your car off the road right away and replace that tire.
Old Dec 17, 2007 | 05:27 PM
96blkonblkse's Avatar
Yeah its pretty dangerous, that happened to my freinds tire on his intrepid (canadian tire brand tires FTMFL), i gave him a set of turnaza EL42's i had laying around and it fixed his problem.
Old Dec 17, 2007 | 08:22 PM
d00df00d's Avatar
Wow. That was nice of you. Those aren't cheap.
coolsun
Wheels/Tires
Nov 13, 2016 05:01 PM
D Mason
Jun 21, 2016 04:43 AM
DC_Juggernaut
Sep 28, 2015 04:07 PM
Garrettz459
Sep 28, 2015 02:50 PM
