GXE pulls to the right on acceleration
Old Dec 14, 2007 | 04:25 PM
Nmax92's Avatar
I don't know whats going on here. When I'm cruising and step on the gas my car pulls to the right. it tracks straight no wheel wobble. I got a set of new tires all four, inner tie rods, outer tie rods are good, and an alignment.
does anyone know whats the deal with this thing?
Old Dec 14, 2007 | 04:52 PM
Greeny's Avatar
¯\(°_o)/¯
Your passenger side control arm bushing is bad(the small front bushing)..most likely due to either a power steering leak,or an engine oil leak from your front main seal..
you can buy a new control assembly with new bushing installed from member internetautomar..--->http://internetautosupply.com/catalog/
or you can get them from ebay..I do recommend replacing both sides while your at it..
Old Dec 14, 2007 | 05:50 PM
Nmax92's Avatar
I just checked his site. Correct me if I'm wrong. He has one that says its the arm with the ball joint attached, is the bushing attached too?
I got an arm from him in the past for my VE. Guality stuff!!
Old Dec 14, 2007 | 05:59 PM
Nmax92's Avatar
MyGreenmax94 - I was hoping for it not to be the the control arm. Its kinda cold in NY to be changing the arm outside lol.
Old Dec 14, 2007 | 06:18 PM
Greeny's Avatar
¯\(°_o)/¯
I got an arm from him in the past for my VE. quality stuff!!
yeah,it comes with all new bushings,and ball joint.
I hear ya,they are forecasting snow here sunday..
Old Dec 14, 2007 | 06:26 PM
BenStoked's Avatar
Jesus was a Zombie.
yeah, according to the discription, it seems more like the bushings.
he said it happened when he gets on the gas, not hits a bump.
I changed the driver side bushings on my car this weekend, and my car is doing the same thing now.(passenger side coming soon...)
Old Dec 18, 2007 | 06:31 PM
traxtar944's Avatar
Would be lost w/out the org
control arm bushings....that is all.
Old Dec 19, 2007 | 04:46 PM
Nmax92's Avatar
thanks guys. when i change the control arms. I'll let you know the result.
Old Jan 12, 2008 | 08:23 PM
Nmax92's Avatar
Is there a difference between the bushings on the control arm for a GXE vs. an SE? I checked out some sites and noticed there are different part numbers for the same year but different trim.
Does anyone know if there are polyurethane bushings for the arms?
Old Jan 12, 2008 | 08:39 PM
BenStoked's Avatar
Jesus was a Zombie.
energy suspension 7.3111 is part for a 4th gen control arm bushing set.
internetautomar has 'em, can be bought elsewhere, too.
the rear bushing will hafta be cut to fit.
as for the difference in part numbers on gxe vs. se, i do not know why there is a difference...
as for bushing replacement, yeah, you can get the bushings for about $50, but, unless you have a hydraulic press, it's worth it to get the control arms new as a whole.
they have bushings, and ball joints. the ball joints and front bushing installed alone are worth the extra 30 each arm.
Old Jan 12, 2008 | 08:49 PM
Nmax92's Avatar
thanks for the info. One last thing. If I do get the control arm w/ the ball joint and bushings(which is a good deal), are the bushings rubber or polyurethane. The reason why I ask is that I'm looking for stiff control. Thats my first step before moving on to shocks/springs etc.
Old Jan 12, 2008 | 09:00 PM
BenStoked's Avatar
Jesus was a Zombie.
rubber...
if you are gonna go that way, plenty of people have gone the way of the poly.
tarun900
19
Dec 20, 2021 06:57 PM
D Mason
Jun 21, 2016 04:43 AM
Need help
23
Oct 2, 2015 08:56 AM
