anyone heard of "cryofuzion"?
Old Dec 20, 2007 | 07:56 PM
gen3fan's Avatar
I read every once in a while about the performance advantages of getting cooler airflow to your intake. I've heard about the various techniques guys come up with besides the cold air intake setup (ice, lunchbox freezer packs, etc.) I goggled and found this thing that some company is making and selling. Its basically a CO2 tank that releases into a sealed chamber adjoining the intake. Its been around for a few years, so maybe I'm the only one who hasn't seen it before.
http://www.cryofusion.com/
If nothing else, there's a couple of interesting (or frightening?) photos there that I got a kick out of, including a setup that makes use of the spent CO2. THAT I've heard of, just never seen it.
Old Dec 20, 2007 | 08:04 PM
EnervinE's Avatar
i has college
Reminds me of a system a friend of mine was telling me about that utilizes the AC compressor in a passive way to cool air temps in an extra intake reservoir. Apparently Ford plans to use it in their new F-series trucks.
I don't get what gains this would provide, though...the temperature of the intake air itself doesnt matter, it just generally means a denser oxygen supply. Adding carbon dioxide seems pointless, even enervative.
Old Dec 20, 2007 | 08:09 PM
gen3fan's Avatar
Originally Posted by EnervinE
Heard of it. Reminds me of a system a friend of mine was telling me about that utilizes the AC compressor in a passive way to cool air temps in an extra intake reservoir. Apparently Ford plans to use it in their new F-series trucks.
wow, I wouldn't think that an a/c compressor was nearly big enough to be able to do that. u learn something every day.
Old Dec 20, 2007 | 09:22 PM
Scottwax's Avatar
That's Mr. Detail to you
Actually, that was something planned for the supercharged Lightning based on the new body style of the F-150 but Ford never actually brought it to market. Supposed to help the engine make 550 hp.
Old Dec 20, 2007 | 10:50 PM
gen3fan's Avatar
the co2 is sealed, its only there for the cooling effect. anyhow, did you see the other thing they're advertising on the bottom of the page called the "cheetah"? its supposed to be for if you're on the strip, a nozzle releases the co2 out the side, which is supposed to rob the guy next to you of intake air, preventing him from getting a good holeshot off the line. i'm sure its mostly a joke. as far as the kit goes though, the question is- "how cold is too cold?"
Old Dec 21, 2007 | 02:30 AM
DasYears
it wouldnt help unless you cooled the air BEFORE it went in the intake. once its in the intake, you are going to have the same quantity of air. cooling it will only make it take up less volume at the point
Old Dec 21, 2007 | 08:27 AM
gen3fan's Avatar
ok, I understand what you're saying
Old Dec 21, 2007 | 09:01 AM
rockfordmaxII's Avatar
cryo2 system is the big one. it uses co2 to rapidly cool air similar to a nitrous system. unlike nitrous systems there does not seem to be a 'shot' size that you can use. many use the system as intercooler coolers
Old Dec 21, 2007 | 02:01 PM
nalc's Avatar
If that's true, then why do people use intercoolers?
Old Dec 21, 2007 | 06:28 PM
foodmanry's Avatar
Da Roller Coaster!
They are a pretty good rap group out of DC.
Old Dec 22, 2007 | 03:14 AM
DasYears
in a turbo car, people use an intercooler because the air that comes out of the turbo is so hot that you would have to run considerably less timing and run richer in order to not get detonation if there was no intercooler. thats not an issue in an NA car.
Old Dec 22, 2007 | 09:10 AM
huyqvu's Avatar
this isnt really going to help unless you're using turbo or sc.
Old Dec 22, 2007 | 09:53 PM
nalc's Avatar
Ah, makes sense.
Wouldn't the cooling help with a sufficiently large intake? cooling it is not going to do **** if the intake pipe isn't wide enough to get enough air for the engine in. but if there is a really big intake pipe, if the intake has more airflow than the engine, cooling it right before the engine would decrease the volume, which would create a little bit of vacuum sucking air into the intake, and denser air at that stage would allow more oxygen into the same cylinder volume, having the same effect as a larger displacement or higher compression?
Old Dec 23, 2007 | 12:28 PM
huyqvu's Avatar
if you're na you would benefit more from a no2 system.
Old Dec 26, 2007 | 10:48 PM
DasYears
no2 or n2o?
D Mason
Jun 21, 2016 04:43 AM
jsmith24
Feb 1, 2016 12:35 AM
jc53
Oct 12, 2015 05:12 AM
220k+ A32
Sep 23, 2015 03:38 PM
