Bleed clutch more?
Old Jan 26, 2008 | 06:04 PM
SKarpenz's Avatar
Bleed clutch more?
Hey guys, today I put on my new clutch slave cylinder and lower clutch hose. I bled the system from the upper and lower bleed screws and it has ample fluid in the reservoir but the clutch feels weaker than before. If I pump the clutch for like a minute in neutral before I begin driving, it feels GREAT, but then it starts feeling like *** again if I let it sit. Soooo, I was thinking I would just bleed it again, but let me know if there is anything else to look for. It isnt leaking or anything anymore, but I bled it till I was pretty sure no air was coming out. Its frustrating, lol.
Old Jan 26, 2008 | 06:40 PM
Maximeltman's Avatar
I did my clutch with a new ss lower hose and it felt much softer than before. that was almost a month ago. Now, it feels a bit firmer.
Old Jan 26, 2008 | 09:56 PM
SKarpenz's Avatar
Harhar. Tonight on the way home from my car meet the clutch just went out. Then it started working again. I guess that air pocket made it somewhere, lol. I'll bleed it more tomorrow.
Old Jan 26, 2008 | 11:23 PM
sahtt57's Avatar
Keep bleeding it, the pressure should be what it was before you had any issues. Are doing the procedure correctly? You need to bleed the lower first, then the upper. You also can't let ANY air get in to the system ANY time throughout the procedure. I know what a PITA it is to have to keep getting under the car, getting the fluid on you, etc. My advice is get some ATE superblue and make 100% it's all changed out. I started this with my brakes and do it with my clutches now as well. Look here to find more details on the procedure Nissan Maxima clutch bleed and potential problems you may encounter/have already encountered.
Expect to put half a bottle through the system to get it perfect.
Old Jan 26, 2008 | 11:35 PM
SKarpenz's Avatar
I just take the front of the intake off to get to the bleeder valve. But yeah, its a PITA, I was doing the bottom first and I guess I'll keep it up tomorrow. Thanks for the info.
Old Jan 27, 2008 | 07:26 PM
SKarpenz's Avatar
I figured it out, the other end of the clutch hose that isnt attached to the slave cyl had ****ty washers on it, and leaked. I got new washers, bled it again, and its perfect.
user 11122324
42
Jul 18, 2022 03:35 PM
Mar 12, 2020 12:06 AM
BkGreen97
Apr 2, 2016 05:47 AM
carlosvq30
Sep 26, 2015 09:44 AM
imported_Nismo_max
Sep 20, 2015 08:19 AM
