How to change thermostat
FIRST! I looked at the fsm and did some searching, but they aren't very detailed. Also, the link for the thermostat change guide is broken, so no luck there.
Is there a guide on how to do this that is more than 3 sentences long? Do I have to completely drain the antifreeze from the car? Do I have to remove anything to get at the thermostat?
Thanks!
Thanks!
Post in the stickies works for me
http://forums.maxima.org/showthread....15#post2506154
Then again, I actually read.
http://forums.maxima.org/showthread.php?t=543975
If you haven't changed coolant in a while, might as well drain it all and fill up with fresh. Otherwise, a fair amount will come out when you remove the hose, and some more when you take the thermostat physically out.
The post above details everything. 1 clamp, 3 bolts, and you're done..
The FSM is perfectly detailed:
That's all you need to do...
jmlee44
Oct 2, 2022 02:13 PM
