Change Rear Spark Plugs 96
Old Feb 2, 2008 | 10:27 PM
MaximaMark123's Avatar
The front 3 plugs are easy to do, no prob.
The rear 3 plugs are not covered in the 2 books I have like they don't exist. How do you get to the 3 rear plugs?
I tried removing the small cap over the red plastic coil and could not move the coil to get to the plug underneath. Do I need to remove the metal tube and all 3 coils at once?
Help?
Old Feb 2, 2008 | 10:55 PM
98SEBlackMax's Avatar
Maxima.org Insomniac
Your not reading those books well enough.
Those are the fuel injectors not the spark plugs...
If you need to replace the three rear INJECTORS than you need to remove the upper intake manifold.
To replace the front 3 spark plugs take off the silver colored plastic cover that says VQ on it.
To replace the rear 3 spark plugs there are gaps in the upper intake manifold to take them out.
Old Feb 3, 2008 | 02:24 AM
pmi3096's Avatar
Wrong section!!
but this link should help sorta show were you need to look. http://www.vqpower.com/v2/readarticle.php?article_id=76
Old Feb 3, 2008 | 06:01 AM
njmaxseltd's Avatar
Go back further twards the fire wall and look down between the intake runners. You'll see the plugs for the 3 rear coil packs. The pic's you have are showing the fuel rail and injectors, not the spark plugs.
You'll need a longer extension to get down the rear spark plug tubes to access the plugs.
Old Feb 3, 2008 | 09:04 PM
Fadrvr's Avatar
three seperate threads on this kids injectors. He thinks they are spark plugs. So close to flaming.
Old Feb 3, 2008 | 09:37 PM
VANGtastic97's Avatar
hahahaha. he's sloooooowly learning
Old Feb 3, 2008 | 10:33 PM
aussie983's Avatar
OMGWTFBBQ
Old Feb 3, 2008 | 10:38 PM
Blackwind's Avatar
take the 405 to I5 to the slawson cut off, get out and cut of your slawson. then go 2 blocks left past the throttle body and BAM you found the other three plugs.
Old Feb 4, 2008 | 05:26 AM
Product_Of_Korea's Avatar
lol yeah i already told him what the pics are in a thread that was bumped from 2005
Old Feb 4, 2008 | 05:46 AM
Also on the rear drivers side coil you will have to take the bracket off that supports the evap canister purge control valve 2 12mm nuts( someone please correct me if i am wrong) hope this helps you out.
Old Feb 4, 2008 | 09:39 AM
According to this thread........
http://forums.maxima.org/showpost.ph...2&postcount=17
you give the impression you know how to change spark plugs?
Explain......
Old Feb 4, 2008 | 09:49 AM
tvis's Avatar
Kids + Maxima's = bad
Old Feb 4, 2008 | 12:52 PM
Navin R Johnson's Avatar
Help?
Ya just remove everything...You should be smoking a cigarette too.
This has too be a joke right? I seen some crazy things in forums, but if you can't tell the difference between a fuel injector and an ignition coil you should NOT be working on your car. DANGER!! Will Robinson DANGER !!!
Old Feb 4, 2008 | 01:02 PM
ajcool2's Avatar
Funniest thread evar LMAO!
Old Feb 4, 2008 | 01:20 PM
EnervinE's Avatar
i has college
Explain......
HAHA nice catch!
Old Feb 4, 2008 | 01:36 PM
CRiME's Avatar
oem ftw!
Yes, Definitely remove the metal tube. Before you do that, be sure to light up a nice, fresh cigarette and have it in your mouth while pulling the tube out.
Old Feb 4, 2008 | 05:20 PM
sparky1562's Avatar
Use a metric screwdriver to.
Old Feb 4, 2008 | 05:29 PM
91parkave's Avatar
watch out for the muffler bearings to. you have to remove those before you can get to the spark plugs. a metric hammer will do the trick though.
Old Feb 4, 2008 | 05:43 PM
Blackwind's Avatar
HAHAHA!! "hey mom i found my special purpose!!"
Old Feb 4, 2008 | 05:46 PM
mevjen's Avatar
The self-oil changing max
dude, you should really clean those spark plugs, they look pretty fouled...
Old Feb 4, 2008 | 11:48 PM
Old Feb 6, 2008 | 10:08 AM
Explain......
Still waiting for a response.....
Old Mar 24, 2008 | 05:47 AM
phatboislim's Avatar
glad i searched..just a friendly bump for any fresh maxima owners out there trying to do their spark plug change...post #3 holds the info needed
Maxboy23
Aug 21, 2015 11:02 AM
Turbobink
Aug 15, 2015 07:20 AM
Balkins
Aug 12, 2015 06:39 AM
1992maximase30
Aug 5, 2015 09:27 PM
maxima297
Aug 3, 2015 12:50 PM
